Posted: 2021-06-28 09:52 PM . Last Modified: 2024-03-14 11:32 PM
Hi All
This is on a Symmetra 40K UPS. We have the following error
Critical - UPS: A runtime alarm threshold violation exists.
The UPS is down to 2 minutes now, is this error just the fact that its only has 2 mins runtime or could this be something else ?
yep so if you adjust that setting the violation should clear (or if you add more batteries i guess).
okay so it seems like you have a runtime threshold configured in the network management card under the UPS tab->Configuration->Power. this is worded as Alarm If Runtime Under: xxx
what is this value set to? do you know why your runtime is so low?
Ah its set to 5mins so that will explain it. A lot of Extra load has been put on it so its dropped runtime quite a bit.
