Which serial cable to upgrade firmware of my SMT750RMI2U?
  • Which serial cable to upgrade firmware of my SMT750RMI2U?
Posted: ‎2021-07-07 11:36 PM . Last Modified: ‎2024-02-29 11:52 PM
2348
Hi there,
I want to upgrade my UPS firmware (current version 6.x). I need a serial cable to do this, so which one is it?
There a two versions of the AP940-0625A cable: RJ45 and RJ50. Which one do I need?
Link RJ50: https://www.ebay.de/itm/APC-940-0625A-Originalkabel-von-APC-fur-USV-Back-UPS-RS-232-RJ50-Datenkabel-...
Link R45: https://www.ebay.de/itm/Original-APC-940-0625A-USV-Kabel-DB9-RJ45-UPS-Power-Supply-Cable-NEU-/272894...
Or can I use a serial to USB cable to perform the upgrade too?
Link serial to USB: https://www.amazon.com/APC-AP9827-USB-cable/dp/B0002WYJSU e.g.
Thanks in advance!
Posted: ‎2021-07-07 11:37 PM . Last Modified: ‎2024-02-29 11:51 PM
You should review Schneider Electric FAQ FA164737 "How do I update the firmware of my SMT, SMX, SMC, or SRT series Smart-UPS?"
On 10/23/2017 12:01 PM, Johannes said:
Which is the firmware part which says that "modbus" is activated?
The firmware needs to be a minimum of 9.x for modbus support and depend on the UPS.
Sorry for the inconvenience. The proper part number is AP940-0625A. That cable is 9 pin serial to RJ50. You will find in some posts and on-line the cable as being described as 9 pin serial to RJ45 which is inaccurate. RJ45 is 8 wire where as RJ50 is 10 wire. The AP940-0625A is 10 wire. The link you provided are for the proper cable. The one listing RJ45 is just being described incorrectly.
The firmware appears to be for a Network Management Card not the Smart-UPS. You can upgrade the firmware of a Network Card using the card wizard. The latest firmware for a Network Card model AP9630, AP9631, AP9635 is 6.5.
http://www.apc.com/us/en/tools/download/download.cfm?sw_sku=SFSUMX650&software_id=MFOI-APKQJS&family...
thank you for your reply.
If it's the RJ50 connector then it should be updated in your manuals too:
http://www.apc.com/salestools/EALN-85BQQ8/EALN-85BQQ8_R1_EN.pdf
Because there is a "RJ45 connector - serial UPS monitoring port"
And it is the firmware version of the UPS because there is no network card connected.
There are 4 firmwares:
1.) USV: 06.5
2.) MCU: 11.0
3.) UBL: 8.2
4.) MBL: 11.0
