Unable to set date-time correctly
  • Unable to set date-time correctly
Posted: ‎2021-06-28 06:24 AM . Last Modified: ‎2024-03-18 02:22 AM
2244
this is my environment.
UPS Model: Smart-UPS SRT 5000
NMC Model: AP9537SUM
NMC Version: v6.5.0
I tried to set the date/time in different ways:
- manually via cli
- manually via webgui
- sync to NTP in my LAN
- sync to public NTP
In every case the configuration is accepted, but the date/time is wrong (every time the date changes, but always in the
future).
One strange case is that if I set "Apply local computer time", after pressing "Apply" I see the correct time, but as soon
as page refreshes the time is wrong again.
Anyone experienced the same? What could I check?
Thank you for help,
Federico
Hmm, if all of the steps you tried don't work (which were what I would've done), there could be a problem with a component on the embedded AP9537SUM Network Management Card module. There is a device on there we call a time crystal that I've seen if it is damaged, aligned incorrectly or something along those lines, this type of issue could happen.
The unfortunate thing is that the NMC is not field replaceable on the UPS unit you have so if technical support can replace this under warranty for you, the entire UPS needs to be replaced as far as I know yell
