Smart UPS Serial Spam
Send InviteCancel
Posted: 2021-06-2806:24 AM. Last Modified: 2024-03-1801:33 AM
Hi, I'm not sure this is the right place to post, If needed I ask some mod to move the conversation 🙂
I'll get straight to it, I've finally been able to comunicate with the UPS by cutting a cable and wiring the RX and TX lines to an arduino with RS232/TTL IC to my pc. The issue is not in the type of connection rather than the spam that the UPS generates, the moment I ask to enter smart mode sending Y it starts to write NA then the line voltage like this:
223.6
NA
223.6
NA
The strange thing that the UPS indeed answers back to commands if spammed enough, if I send in a train of R it will eventually get the command and stop writing BYE, same with A to test the Leds. Connected at 2400 baud 8N1 as told everywhere.
How do I stop this flow of useless data? I need to know Power, Battery Voltage and Temperature not line voltage 🙂
The unit is a SmartUPS 2200VA (230V), It's huge 40kg white tower with the lower bay for the batteries.
