Posted: 2021-06-28 06:24 AM . Last Modified: 2024-03-18 02:22 AM
I have several racks in a data Center that have the AP 7894, 7862, and 7941 PDUs... I need the total power in watts OID for each of those APC models. Can anyone assist with that, or point me to the right docs that have the OIDs listed for those models?
Thanks in advance!
-Scott
Message was edited by: swpaisley
Posted: 2021-06-28 06:25 AM . Last Modified: 2024-03-18 01:33 AM
no problem 🙂
Posted: 2021-06-28 06:24 AM . Last Modified: 2024-03-18 01:33 AM
keep in mind that these models only measure amps and they assume voltage and power factor (which can be adjusted). thus the watts calculation is a result of those. you can try these OIDs:
.iso.org.dod.internet.private.enterprises.apc.products.hardware.rPDU.rPDUIdent.rPDUIdentDevicePowerWatts / .1.3.6.1.4.1.318.1.1.12.1.16
.iso.org.dod.internet.private.enterprises.apc.products.hardware.rPDU.rPDUIdent.rPDUIdentDevicePowerFactor / .1.3.6.1.4.1.318.1.1.12.1.17
.iso.org.dod.internet.private.enterprises.apc.products.hardware.rPDU.rPDUIdent.rPDUIdentDevicePowerVA / .1.3.6.1.4.1.318.1.1.12.1.18
our newer PDUs (AP8XXX) actually measure kW, kWh, amps, and volts so these are real time measurements versus the AP7XXX series above that measure amps and calculate the rest. hope that helps.
Thanks for the OIDs, I'll test these and let you know how it pans out.
no problem 🙂
