Oid descrition for .1.3.6.1.4.1.318.1.4.*
  • Oid descrition for .1.3.6.1.4.1.318.1.4.*
5060
139
Erasmus_apc
Sisko Erasmus_apc
112
Posted: ‎2021-06-28 06:25 AM . Last Modified: ‎2024-03-18 01:33 AM
1729
I get the below messages from APC 7920 PDU and I want to know the meanings.
.iso.org.dod.internet.private.enterprises.apc.products.experimental.2.6.1.5.1 = INTEGER: 2
.iso.org.dod.internet.private.enterprises.apc.products.experimental.2.6.1.5.2 = INTEGER: 2
.iso.org.dod.internet.private.enterprises.apc.products.experimental.2.6.1.5.3 = INTEGER: 1
.iso.org.dod.internet.private.enterprises.apc.products.experimental.2.6.1.5.4 = INTEGER: 2
.iso.org.dod.internet.private.enterprises.apc.products.experimental.2.6.1.5.5 = INTEGER: 2
.iso.org.dod.internet.private.enterprises.apc.products.experimental.2.6.1.5.6 = INTEGER: 2
who can tell me the OID description under .1.3.6.1.4.1.318.1.4 ?
Can I get the type of web access through SNMP, not be allowed, http or https?
thanks!
Posted: ‎2021-06-28 06:25 AM . Last Modified: ‎2024-03-18 01:32 AM
ohhh ok. i dont believe so. you can access the device via telnet or ssh and you can see if it is HTTP or HTTPS there OR retrieve the configuration file via FTP which is called config.ini.
these experimental OIDs are for internal APC reference use and are not intended to be used by end users. any available device data is listed under the other named trees and these are most likely duplicates anyway when used in testing or for other functions.
and if i understand you correctly, you can disable SNMP access and web access via HTTP or HTTPS if you choose. you can also change HTTP or HTTPS port access numbers for security if that is a concern.
Appreciate your quick response. I might not discirbe the problem clearly.
User can visit the PDU through web console, i.e., http://ipaddress.
In the web console, use could modify the web access to https. After reboot, user could not visit the PDU through http. Instead, visit the PDU through https.
Is there any OID(.1.3.6.1.4.1.318.1.4.*) which reflects the web access, http or https?
