Smart-ups RT10000 not charging battery and always beep
  • Smart-ups RT10000 not charging battery and always beep
Posted: ‎2021-06-29 04:35 AM . Last Modified: ‎2024-03-13 01:41 AM
1054
Hi
i have APC smart-ups RT10000 always beep every 2 second and red flash light for battery fault is on . i checked the all 4 battery inside all gives 108 v DC foe each battery which is correct for total volts but the smart-ups keep beep every 2 second i re move all the battery and reinstall them again .. but no luck
i open the 4 battery from inside and found 8 small battery 12 v dc inside all connected together each one of them give 13.5 volt and all give 108 volt total
i power off the smart-ups rt10000 and power on again .. beep and red flash light still there ........ even if turn the switch to bypass the battery also no luck
could you please help me to find out what is the problem ?
best regards
adly
Posted: ‎2021-06-29 04:36 AM . Last Modified: ‎2024-03-13 01:40 AM
this is the log file
Date Time Event
Date Time Event
09/11/2012 09:25:27 UPS: The battery is not installed properly.
09/11/2012 09:25:11 UPS: The battery is now installed.
09/11/2012 09:24:54 UPS: The battery is not installed properly.
09/11/2012 09:24:36 UPS: The battery is now installed.
09/11/2012 09:23:47 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/11/2012 09:21:04 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/11/2012 09:17:10 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/11/2012 09:15:31 UPS: The battery is not installed properly.
09/11/2012 09:15:13 UPS: The battery is now installed.
09/11/2012 09:14:21 UPS: The battery is not installed properly.
09/11/2012 09:13:47 UPS: The battery is now installed.
09/11/2012 09:10:41 UPS: The battery is not installed properly.
09/11/2012 09:10:23 UPS: The battery is now installed.
09/11/2012 09:04:58 UPS: The battery is not installed properly.
09/11/2012 09:04:41 UPS: The battery is now installed.
09/11/2012 08:59:17 UPS: The battery is not installed properly.
09/11/2012 08:59:00 UPS: The battery is now installed.
09/11/2012 08:58:25 UPS: The battery is not installed properly.
09/11/2012 08:58:09 UPS: The battery is now installed.
09/11/2012 08:57:53 UPS: The battery is not installed properly.
09/11/2012 08:57:35 UPS: The battery is now installed.
09/11/2012 08:55:52 UPS: The battery is not installed properly.
09/11/2012 08:55:35 UPS: The battery is now installed.
09/11/2012 08:54:44 UPS: The battery is not installed properly.
09/11/2012 08:54:27 UPS: The battery is now installed.
09/11/2012 08:53:02 UPS: The battery is not installed properly.
09/11/2012 08:52:43 UPS: The battery is now installed.
09/11/2012 08:26:43 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/11/2012 08:23:14 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/11/2012 08:19:09 UPS: The battery is not installed properly.
09/11/2012 08:18:53 UPS: The battery is now installed.
09/11/2012 07:33:04 UPS: The battery is not installed properly.
09/11/2012 07:32:46 UPS: The battery is now installed.
09/11/2012 07:31:03 UPS: The battery is not installed properly.
09/11/2012 07:30:48 UPS: The battery is now installed.
09/11/2012 07:29:22 UPS: The battery is not installed properly.
09/11/2012 07:29:04 UPS: The battery is now installed.
09/11/2012 07:28:47 UPS: The battery is not installed properly.
09/11/2012 07:28:14 UPS: The battery is now installed.
09/11/2012 07:27:22 UPS: The battery is not installed properly.
09/11/2012 07:27:05 UPS: The battery is now installed.
09/11/2012 07:22:33 UPS: The battery is not installed properly.
09/11/2012 07:21:59 UPS: The battery is now installed.
09/11/2012 07:17:26 UPS: The battery is not installed properly.
09/11/2012 07:17:07 UPS: The battery is now installed.
09/11/2012 07:15:59 UPS: The battery is not installed properly.
09/11/2012 07:15:43 UPS: The battery is now installed.
09/11/2012 07:15:26 UPS: The battery is not installed properly.
09/11/2012 07:14:51 UPS: The battery is now installed.
09/11/2012 07:14:34 UPS: The battery is not installed properly.
09/11/2012 07:14:18 UPS: The battery is now installed.
09/11/2012 07:13:26 UPS: The battery is not installed properly.
09/11/2012 07:13:08 UPS: The battery is now installed.
09/11/2012 07:12:17 UPS: The battery is not installed properly.
09/11/2012 07:12:01 UPS: The battery is now installed.
09/11/2012 07:07:10 UPS: The battery is not installed properly.
09/11/2012 07:06:54 UPS: The battery is now installed.
09/11/2012 07:05:11 UPS: The battery is not installed properly.
09/11/2012 07:04:21 UPS: The battery is now installed.
09/11/2012 07:03:29 UPS: The battery is not installed properly.
09/11/2012 07:02:20 UPS: The battery is now installed.
09/11/2012 07:02:03 UPS: The battery is not installed properly.
09/11/2012 07:01:45 UPS: The battery is now installed.
09/11/2012 06:59:47 UPS: The battery is not installed properly.
09/11/2012 06:59:30 UPS: The battery is now installed.
09/11/2012 06:58:37 UPS: The battery is not installed properly.
09/11/2012 06:58:22 UPS: The battery is now installed.
09/11/2012 06:56:39 UPS: The battery is not installed properly.
09/11/2012 06:56:04 UPS: The battery is now installed.
09/11/2012 06:54:56 UPS: The battery is not installed properly.
09/11/2012 06:54:40 UPS: The battery is now installed.
09/11/2012 06:54:06 UPS: The battery is not installed properly.
09/11/2012 06:52:24 UPS: The battery is now installed.
09/11/2012 06:50:57 UPS: The battery is not installed properly.
09/11/2012 06:50:08 UPS: The battery is now installed.
09/11/2012 06:49:51 UPS: The battery is not installed properly.
09/11/2012 06:49:33 UPS: The battery is now installed.
09/11/2012 06:47:15 UPS: The battery is not installed properly.
09/11/2012 06:44:58 UPS: The battery is now installed.
09/11/2012 06:44:08 UPS: The battery is not installed properly.
09/11/2012 06:43:52 UPS: The battery is now installed.
09/11/2012 06:43:18 UPS: The battery is not installed properly.
09/11/2012 06:42:59 UPS: The battery is now installed.
09/11/2012 06:42:42 UPS: The battery is not installed properly.
09/11/2012 06:42:26 UPS: The battery is now installed.
09/11/2012 06:42:09 UPS: The battery is not installed properly.
09/11/2012 06:41:51 UPS: The battery is now installed.
09/11/2012 06:40:09 UPS: The battery is not installed properly.
09/11/2012 06:39:52 UPS: The battery is now installed.
09/11/2012 06:39:35 UPS: The battery is not installed properly.
09/11/2012 06:39:18 UPS: The battery is now installed.
09/11/2012 06:38:26 UPS: The battery is not installed properly.
09/11/2012 06:38:11 UPS: The battery is now installed.
09/11/2012 06:37:01 UPS: The battery is not installed properly.
09/11/2012 06:36:11 UPS: The battery is now installed.
09/11/2012 06:33:37 UPS: The battery is not installed properly.
09/11/2012 06:33:03 UPS: The battery is now installed.
09/11/2012 06:31:55 UPS: The battery is not installed properly.
09/11/2012 06:31:48 UPS: A discharged battery condition no longer exists.
09/11/2012 06:31:20 UPS: The battery is now installed.
09/11/2012 06:31:03 UPS: The battery is not installed properly.
09/11/2012 06:30:47 UPS: The battery is now installed.
09/11/2012 06:29:21 UPS: The battery is not installed properly.
09/11/2012 06:29:04 UPS: The battery is now installed.
09/11/2012 06:26:30 UPS: The battery is not installed properly.
09/11/2012 06:26:13 UPS: The battery is now installed.
09/11/2012 06:25:38 UPS: The battery is not installed properly.
09/11/2012 06:25:05 UPS: The battery is now installed.
09/11/2012 06:21:05 UPS: The battery is not installed properly.
09/11/2012 06:20:15 UPS: The battery is now installed.
09/11/2012 06:19:06 UPS: The battery is not installed properly.
09/11/2012 06:18:49 UPS: The battery is now installed.
09/11/2012 06:18:33 UPS: The battery is not installed properly.
09/11/2012 06:17:42 UPS: The battery is now installed.
09/11/2012 06:16:16 UPS: The battery is not installed properly.
09/11/2012 06:15:59 UPS: The battery is now installed.
09/11/2012 06:15:42 UPS: The battery is not installed properly.
09/11/2012 06:15:25 UPS: The battery is now installed.
09/11/2012 06:14:33 UPS: The battery is not installed properly.
09/11/2012 06:14:16 UPS: The battery is now installed.
09/10/2012 16:30:26 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 16:27:26 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 16:26:15 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 16:22:28 UPS: The battery power is too low to support the load; if power fails, the UPS will be shut down immediately.
09/10/2012 16:22:24 UPS: No longer in bypass.
09/10/2012 16:22:12 UPS: A discharged battery condition no longer exists.
09/10/2012 16:22:11 UPS: In bypass in response to the bypass switch at the UPS, typically for maintenance.
09/10/2012 16:21:31 UPS: Synchronized command aborted.
09/10/2012 16:18:58 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 16:10:21 UPS: The battery power is too low to support the load; if power fails, the UPS will be shut down immediately.
09/10/2012 16:10:18 UPS: No longer in bypass.
09/10/2012 16:09:42 UPS: A discharged battery condition no longer exists.
09/10/2012 16:09:41 UPS: In bypass in response to the bypass switch at the UPS, typically for maintenance.
09/10/2012 16:03:34 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:57:08 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:37:50 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:33:00 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:29:52 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:26:51 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:24:40 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:20:12 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:16:07 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:13:05 UPS: The battery is not installed properly.
09/10/2012 15:12:47 UPS: The battery is now installed.
09/10/2012 15:11:36 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:11:24 UPS: The battery is not installed properly.
09/10/2012 15:11:04 UPS: The battery is now installed.
09/10/2012 15:10:33 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:09:57 UPS: The battery is not installed properly.
09/10/2012 15:09:40 UPS: The battery is now installed.
09/10/2012 15:09:05 UPS: The battery is not installed properly.
09/10/2012 15:08:32 UPS: The battery is now installed.
09/10/2012 15:07:05 UPS: The battery is not installed properly.
09/10/2012 15:06:49 UPS: The battery is now installed.
09/10/2012 15:06:04 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 15:05:41 UPS: The battery is not installed properly.
09/10/2012 15:05:06 UPS: The battery is now installed.
09/10/2012 15:02:33 UPS: The battery is not installed properly.
09/10/2012 15:02:00 UPS: The battery is now installed.
09/10/2012 15:00:16 UPS: The battery is not installed properly.
09/10/2012 15:00:00 UPS: The battery is now installed.
09/10/2012 14:59:42 UPS: The battery is not installed properly.
09/10/2012 14:59:25 UPS: The battery is now installed.
09/10/2012 14:59:08 UPS: The battery is not installed properly.
09/10/2012 14:58:51 UPS: The battery is now installed.
09/10/2012 14:58:34 UPS: The battery is not installed properly.
09/10/2012 14:58:18 UPS: The battery is now installed.
09/10/2012 14:58:01 UPS: The battery is not installed properly.
09/10/2012 14:57:42 UPS: The battery is now installed.
09/10/2012 14:56:36 UPS: The battery is not installed properly.
09/10/2012 14:56:18 UPS: The battery is now installed.
09/10/2012 14:55:45 UPS: The battery is not installed properly.
09/10/2012 14:55:09 UPS: The battery is now installed.
09/10/2012 14:54:02 UPS: The battery is not installed properly.
09/10/2012 14:53:44 UPS: The battery is now installed.
09/10/2012 11:33:31 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 11:28:00 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 11:27:20 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 11:24:20 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 11:13:38 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 11:10:13 System: Configuration change. System location.
09/10/2012 11:10:13 System: Configuration change. System contact.
09/10/2012 11:10:12 System: Configuration change. System name.
09/10/2012 11:02:02 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 11:01:08 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 10:55:42 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 10:42:32 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 10:35:17 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 10:31:18 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 10:27:19 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 10:22:40 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 10:12:28 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 09:15:44 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 09:12:44 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 09:12:30 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 09:08:12 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/10/2012 09:00:27 UPS: The battery is not installed properly.
09/10/2012 09:00:08 UPS: The battery is now installed.
09/10/2012 08:59:51 UPS: The battery is not installed properly.
09/10/2012 08:58:44 UPS: The battery is now installed.
09/10/2012 08:58:09 UPS: The battery is not installed properly.
09/10/2012 08:55:54 UPS: The battery is now installed.
09/10/2012 08:55:37 UPS: The battery is not installed properly.
09/10/2012 08:54:10 UPS: The battery is now installed.
09/10/2012 08:53:55 UPS: The battery is not installed properly.
09/10/2012 08:53:02 UPS: The battery is now installed.
09/10/2012 08:52:45 UPS: The battery is not installed properly.
09/10/2012 08:52:29 UPS: The battery is now installed.
09/10/2012 08:51:38 UPS: The battery is not installed properly.
09/10/2012 08:51:20 UPS: The battery is now installed.
09/10/2012 08:50:28 UPS: The battery is not installed properly.
09/10/2012 08:50:12 UPS: The battery is now installed.
09/10/2012 08:49:54 UPS: The battery is not installed properly.
09/10/2012 08:49:38 UPS: The battery is now installed.
09/10/2012 08:48:28 UPS: The battery is not installed properly.
09/10/2012 08:48:12 UPS: The battery is now installed.
09/09/2012 14:02:33 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/09/2012 13:54:45 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/09/2012 13:19:49 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/09/2012 13:16:27 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/09/2012 13:07:39 UPS: The battery is not installed properly.
09/09/2012 13:07:07 UPS: Self-Test Failed
09/09/2012 13:06:53 UPS: The output power is now turned on.
09/09/2012 13:06:53 UPS: The battery is now installed.
09/09/2012 13:06:51 UPS: The battery power is too low to support the load; if power fails, the UPS will be shut down immediately.
09/09/2012 13:06:22 UPS: The battery is not installed properly.
09/09/2012 13:06:04 UPS: The output power is turned off.
09/09/2012 13:05:40 UPS: Self-Test Failed
09/09/2012 13:05:29 UPS: The output power is now turned on.
09/09/2012 13:05:27 UPS: The battery is now installed.
09/09/2012 13:05:25 UPS: At least one faulty battery exists.
09/09/2012 13:05:24 UPS: The output power is turned off.
09/09/2012 13:05:23 UPS: Synchronized UPS failed to complete the command.
09/09/2012 13:04:47 UPS: Started a reboot process.
09/09/2012 12:50:35 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/09/2012 12:42:47 UPS: A graceful shutdown process is being used to shut down the load equipment before the UPS turns off. Initiated by Web user '' from .11.
09/09/2012 12:42:46 UPS: Synchronized command aborted.
09/09/2012 12:40:24 System: Web user 'apc' logged in from 4.30.8.11 [nsa430-000001.crowncork.com].
09/09/2012 12:33:32 System: Web user 'apc' logged out from 4.30.8.11 [nsa430-000001.crowncork.com].
09/09/2012 12:30:24 System: Event Log cleared.
Replies 6
is it the red LED with an X in a box or just a light with a red X?
do you have the logs for the network management card available?
instructions on downloading logs are available in knowledge base FA156131 @ http://www.apc.com/site/support/index.cfm/faq/
yes the red LED is an X in the box flashing every 2second for long time and suddenly the battery stop the beep and the red LED light turned off for 10 or 15 second and i can see the charging level 2 green LED light for 10 second only and battery come back again to beep and the red LED ( x in the box ) come back again.
battery charge now is 32% two green led only
Date Time Event
Date Time Event
09/09/2012 12:42:47 UPS: A graceful shutdown process is being used to shut down the load equipment before the UPS turns off. Initiated by Web user '' from 4.30.8.11.
Message was edited by: crownjeddah
Posted: ‎2021-06-29 04:36 AM . Last Modified: ‎2024-03-13 01:41 AM
i asked someone more familiar with the UPS and they indicated that if it were them, they'd try replacing the batteries first even though the voltage is good.
before i suggest you actually pursue that though, can you please let me know the serial number of the UPS please?
hi
thank you for your reply
this is the information for the UPS
Model: Smart-UPS RT 10000 RM XL
Position: RACK
Serial Number: IS1038000600
Firmware Revision: 476.18.W
Manufacture Date: 09/13/10
can you let me know where this unit is installed? the symptoms indicate bad batteries but 2 years is on the low side for battery life. if its in a warmer closet or rack, this could also be the case or if there are a lot of power issues in the area where the batteries are used more frequently. you could also try to do a self test and see what happens (you can hold down the test button on the front of the UPS) but depending on the issue, it could potentially turn the output of the UPS off.
Date Time Event
Date Time Event
