Smart-UPS VT 40 kVA and mechanical bypass
  • Smart-UPS VT 40 kVA and mechanical bypass
chaser_apc
Crewman chaser_apc
Crewman
Posted: ‎2021-07-29 11:19 PM . Last Modified: ‎2024-02-14 10:10 PM
3079
We have Smart-UPS VT 40 kVA w/4 Batt Mod Exp to 4, int Maint Bypass, Parallel Capable SUVTP40KH4B4S, PS0813240713, Firmware Revision: 912.0405.I.
There are two critical mistakes:
In bypass in response to an internal hardware fault.
A power module fault exists.
Can we try to reboot to get rid of them?
Bellow – our adventures…
01.12.2015
07:53:13
UPS: In bypass in response to the UPS front-panel or a user-initiated software command, typically for maintenance.
01.12.2015
07:53:12
UPS: Restored the local network management interface-to-UPS communication.
01.12.2015
07:52:47
System: Network service started. System IP is 10.4.142.230 from manually configured settings.
01.12.2015
07:52:47
System: Warmstart.
01.12.2015
07:51:49
UPS: The output power is now turned on.
01.12.2015
07:51:48
01.12.2015
07:48:50
UPS: An internal mechanical bypass no longer exists.
01.12.2015
07:48:30
UPS: The output power is turned off.
01.12.2015
07:48:29
UPS: The external Switch Gear Q003 has opened.
01.12.2015
07:47:38
System: NTP update failure.
01.12.2015
07:47:28
01.12.2015
07:47:28
UPS: An internal mechanical bypass exists.
01.12.2015
07:47:28
UPS: The external Switch Gear Q003 has closed.
01.12.2015
07:46:04
01.12.2015
07:46:03
UPS: An input voltage or frequency problem no longer prevents switching to bypass mode.
01.12.2015
07:45:47
01.12.2015
07:45:41
01.12.2015
07:45:28
01.12.2015
07:45:28
01.12.2015
07:40:42
UPS: An input voltage or frequency problem prevents switching to bypass mode.
02.12.2015
01:53:51
UPS: In bypass in response to an internal hardware fault.
02.12.2015
01:53:51
UPS: A power module fault exists.
02.12.2015
00:15:39
02.12.2015
00:15:18
02.12.2015
00:15:17
02.12.2015
00:14:57
02.12.2015
00:14:57
  • bypass
  • mechanical
chaser_apc
Crewman chaser_apc
Crewman
Posted: ‎2021-07-29 11:19 PM . Last Modified: ‎2024-02-14 02:20 AM
Bill, thanks a lot for your reply.
We have done restart of the device. And “raw status” now is OK. No mistakes at all!
M States = 07 04 04
00000000 00000000
00000000 02
Thank you!
Posted: ‎2021-07-29 11:19 PM . Last Modified: ‎2024-01-29 11:37 PM
Hello Vladimir,
I suggest first contacting the technical support group for your region:
http://www.apc.com/site/support/index.cfm/contact-information/ (choose your county with the drop down menu, so it will give you the approriate tech support phone
chaser_apc
Crewman chaser_apc
Crewman
M States = 07 04 04
00000000 00000000
00000000 02
Thank you!
