Smart UPS - SUVTP10kH2B2S UPS: In bypass in response to an internal hardware fault
  • Smart UPS - SUVTP10kH2B2S UPS: In bypass in response to an internal hardware fault
Posted: ‎2021-06-26 02:46 AM . Last Modified: ‎2024-03-19 01:52 AM
886
Hello All,
We have 2 UPS in parallel configuration on a location. Recently both the UPS just shutdown itself as well as the load, however just before the shutdown following alerts were received from UPS. we had 2 instances of UPS complete shutdown within 36 hours.
Device UPS: The external Switch Gear Q004 has opened.
Device UPS: The output power is turned off.
Device UPS: In bypass in response to an internal hardware fault.
Device UPS: Return from bypass, internal hardware fault no longer present.
On First Instance found as below;
UPS was totally Shutdown & No Display.
The MCB supplying mains input power to UPS were tripped.
On Second Instance
We would like to have your expertise for the below queries;
  • What are the reason for UPS to generate an internal hardware fault.
  • Why did the UPS Shutdown completely.
  • What had caused the MCB to trip.
  • Though the battery were still within the UPS, why didn’t UPS go on battery power rather than shutting down.
  • Data Center & Facility 3 Phase UPS
You should contact local support for assistance. They will require logs and help you troubleshoot the issue. You will find local support contact information at this link
http://www.apc.com/us/en/support/contact-us/index.jsp
