Smart-UPS RT 10000 XL: Bad output voltage condition
Send InviteCancel
Posted: 2021-06-2808:18 AM. Last Modified: 2024-03-1711:58 PM
last week apparently our UPS went into Bypass mode after an Self Test. 2 minutes after self-test it reported an error in diagnostics and went into Bypass mode with the error: Bad output voltage condition
Everything seems just fine, except Battery Capacity is slowly going down off course
Anyone has a suggestion what to do next or what it could be?
I did restarted the Self Test manually hoping after a run it would get back into normal operation mode, but that is still running, anyone has an idea how long a self test actually needs?
