Posted: 2021-06-28 09:34 PM . Last Modified: 2024-03-14 11:49 PM
I picked up a used Smart-UPS 750 from a company that was getting rid of it. They said that it didn't work. I still took it home optimistically hoping to use it on my computer at home (I thought that it might be a simple fix like buying a replacement battery). First things first; I'm new to this kind of UPS, and therefore I have several questions.
First - The UPS does not power on. No lights, no sound, nothing at all. I decided to pull out off the front cover and have a look inside. The battery looks great... In fact, the whole unit looks almost like new. I got out a multimeter and tested for continuity of the wires. The two middle wires connected fine. The two outside wires did not. Is this normal?
Second - On the back is a big plastic cover with the words under it "Battery Connector". I thought that all of the battery backup was handled inside the unit. I tried to open it up and couldn't. What is this used for? Do I have to use it? How am I supposed to open it up?
Third - Seeing that this is some kind of server UPS, would it work for a personal computer setup?
Is the entire UPS shot or is it just the battery?
~Chris
You would want to take a measurement off the connector used to connect the battery to the UPS itself.
Here is a diagram of my battery (actually it's two batteries):
Edit: Couldn't get my diagram to show up right.
I've ordered it like this:
1 - 3 - 4 - 2
1 and 4 are negative. 3 and 2 are positive.
1 is connected to 2 and 3 is connected to 4. When testing for continuity, 3 and 4 connect, but 1 and 2 do not. 1 and 2 lead to a connector seems to just slide into the UPS. 3 and 4 must connect the two batteries together.
Which set am I supposed to check the voltage with? Shouldn't both sets of wires make a circuit?
~Chris
Message was edited by: geeked
