  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Smart UPS 420 fails with system overload repeatable on saturday afternoon between 3 and 4 a clock pm
  • Communities
  • Smart UPS 420 fails with system overload repeatable on saturday afternoon between 3 and 4 a clock pm
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
ecaroh_apc
ecaroh_apc
Posted: ‎2021-06-30 11:07 PM
This was originally posted on APC forums on 11/23/2015
I have an SMART UPS 420 with batteries one year old. There should be no battery overload, cause besides a modem and a router only one small server is attached. APCUPSD says it has 33 % UPS Load, 100 % Battery capacity and 32 mins run time remaining.
The UPS suddenly fails supplying power. The server and the modem are powered of. The UPS has an ongoing beep and the system overload LED is on. I have to switch the UPS on again.
The surprising fact is, that this happened round about 5 times in the last year always on a saturday afternoon between 3 and 4 pm. There are no hints from the apcupsd event logs. I have no clue where to start, cause i can not imagine an overload causing the situation. Especially when there should be not more load on the weekend. The monitoring of the server has no hint of extra cpu load at this time. And there has been more load on it while it worked without outage. To reduce it i bought a second UPS and divided system load between them.
Below the output of apcupsd running on linux with serial cable. Does anybody have ideas of a saturday afternoon overload? The last outage happend apr. at 4:00 pm 1 and a half hour before the last log line on 2015-11-21 17:23:38 with message unknown startup succeeded when i bring back the ups online again.
Just a guess; can apcupsd on linux shut down the power via the serial cable? Then it maybe a fault on apcupsd side?
This are samples of "unknown startup succeeded" - always saturday after a shutdown/overload where i started the ups again:
  1 2015-11-21 17:23:38 +0100
  2 2015-10-24 16:56:27 +0200
  3 2015-08-29 17:39:41 +0200
  4 2015-07-18 09:20:09 +0200
  5 2015-07-04 11:22:44 +0200
  6 2015-03-21 13:18:41 +0100
  7 2015-01-17 15:28:47 +0100
  8 2014-12-06 15:20:39 +0100
  9 2014-11-15 16:47:59 +0100
10 2014-11-08 17:28:59 +0100
11 2014-10-11 17:20:36 +0200
Monitoring: of-srv-ipf-1
 UPS Model: Smart-UPS 420
  UPS Name: UPS_IDEN
   APCUPSD: Version 3.14.10
    Status: ONLINE
Last UPS Self Test: NO
Last Test Date: Not found
Utility Voltage: 233.2 VAC
   Line Minimum: 231.8 VAC
   Line Maximum: 233.2 VAC
    Output Freq: 50.0 Hz
2015-11-21 17:23:38 +0100 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-10-24 16:56:27 +0200 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-09-17 15:58:20 +0200 Power is back. UPS running on mains.
2015-09-17 15:58:18 +0200 Power failure.
2015-08-29 17:39:41 +0200 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-08-29 16:31:06 +0200 apcupsd shutdown succeeded
2015-08-29 16:31:06 +0200 apcupsd exiting, signal 15
2015-08-29 14:52:36 +0200 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-08-29 14:49:06 +0200 apcupsd shutdown succeeded
2015-08-29 14:49:06 +0200 apcupsd exiting, signal 15
2015-08-25 15:39:32 +0200 Power is back. UPS running on mains.
2015-08-25 15:39:30 +0200 Power failure.
2015-08-15 16:22:47 +0200 UPS Self Test completed: Battery OK
2015-08-15 16:22:39 +0200 UPS Self Test switch to battery.
2015-08-01 16:22:13 +0200 UPS Self Test completed: Battery OK
2015-08-01 16:22:06 +0200 UPS Self Test switch to battery.
2015-07-24 14:44:00 +0200 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-07-24 14:39:54 +0200 apcupsd shutdown succeeded
2015-07-24 14:39:54 +0200 apcupsd exiting, signal 15
2015-07-18 16:22:30 +0200 UPS Self Test completed: Battery OK
2015-07-18 16:22:27 +0200 UPS Self Test switch to battery.
2015-07-18 09:20:09 +0200 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-07-18 09:16:43 +0200 apcupsd shutdown succeeded
2015-07-18 09:16:43 +0200 apcupsd exiting, signal 15
2015-07-04 11:22:44 +0200 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-07-04 11:19:17 +0200 apcupsd shutdown succeeded
2015-07-04 11:19:17 +0200 apcupsd exiting, signal 15
2015-06-01 03:02:31 +0200 Power is back. UPS running on mains.
2015-06-01 03:02:29 +0200 Power failure.
2015-06-01 03:01:47 +0200 Power is back. UPS running on mains.
2015-06-01 03:01:45 +0200 Power failure.
2015-04-01 17:24:35 +0200 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-04-01 17:21:03 +0200 apcupsd shutdown succeeded
2015-04-01 17:21:03 +0200 apcupsd exiting, signal 15
2015-03-21 13:18:41 +0100 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-03-21 13:15:17 +0100 apcupsd shutdown succeeded
2015-03-21 13:15:17 +0100 apcupsd exiting, signal 15
2015-01-28 11:11:27 +0100 Power is back. UPS running on mains.
2015-01-28 11:11:26 +0100 Power failure.
2015-01-25 12:40:48 +0100 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-01-25 12:37:30 +0100 apcupsd shutdown succeeded
2015-01-25 12:37:30 +0100 apcupsd exiting, signal 15
2015-01-17 15:28:47 +0100 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-01-14 19:23:09 +0100 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2015-01-14 19:19:46 +0100 apcupsd shutdown succeeded
2015-01-14 19:19:46 +0100 apcupsd exiting, signal 15
2014-12-20 15:17:33 +0100 UPS Self Test completed: Battery OK
2014-12-20 15:17:26 +0100 UPS Self Test switch to battery.
2014-12-06 15:20:39 +0100 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
2014-11-15 16:47:59 +0100 apcupsd 3.14.10 (13 September 2011) unknown startup succeeded
output of apcupsd.conf without comments:
UPSCABLE smart
UPSTYPE apcsmart
DEVICE /dev/ttyS0
LOCKFILE /var/lock
SCRIPTDIR /etc/apcupsd
PWRFAILDIR /etc/apcupsd
NOLOGINDIR /etc
ONBATTERYDELAY 6
BATTERYLEVEL 5
MINUTES 3
TIMEOUT 0
ANNOY 300
ANNOYDELAY 60
NOLOGON disable
KILLDELAY 0
NETSERVER on
NISIP 0.0.0.0
NISPORT 3551
EVENTSFILE /var/log/apcupsd.events
EVENTSFILEMAX 10
UPSCLASS standalone
UPSMODE disable
STATTIME 0
STATFILE /var/log/apcupsd.status
LOGSTATS off
DATATIME 0
Replies 0
