Posted: 2021-06-28 05:45 AM . Last Modified: 2024-03-18 03:17 AM
Try connect to APC UPS RM 750 (SMT750RMI2U) via serial interface and cable that was with device 940-625A. Used real COM1 port where OK work early old my UPS SMART 1000.
I try to use software:
But device not detected. COM Port not answer.
By post :
I have information that SMT750 should work with serial port in any case.
When i test to use with USB connection PowerChute Business 9.2 detect ups OK .
I manual described that can work or serial or USB connection in one time. May be need switch by some procedure ?
Factory reset not help in my case.
SN: AS1621241318
What software are you trying to connect to the the UPS over serial comm? If anything other than PowerChute Business Edition it is not supported. If PowerChute Business Edition is failing to discover the UPS over serial comm what version of PowerChute are you installing?
Thanks for SerialTerm.exe. By this apps I detected wrong MB cable connector. They was with other order of pins.
And now I know that new SMART-UPS use SPEED 9600.8.n.1.n, with old SMART-UPS used speed 2400.8.n.1.n
At image show order of pins.
But now other problem with start Agent.
After many reinstall of program agent 9.2, now not started service of PowerChute Business Edition Agent.
| 7024 | Error | Microsoft-Windows-Service Control Manager | System | 03.03.2017 4:20:05 |
The APC PBE Agent service terminated with the following service-specific error: The operation completed successfully.
| 101 | Error | APCPBEAgent | Application | 03.03.2017 4:20:04 |
Error: 0, Time out 90 seconds. Service start operation canceled.
But early at this host agent started correctly.
It link not resolve same problem.
Server Core HV-2016. USB connection. APC UPS RM 750.
Logs: pcbe.log
2017-03-02 19:41:26,108 [main] INFO - [application.PicardApplication] - Legacy logging adapter enabled.2017-03-02 19:41:26,124 [main] INFO - [application.PicardApplication] Java Runtime: Java(TM) SE Runtime Environment (version: 1.8.0_31)2017-03-02 19:41:26,124 [main] INFO - [application.PicardApplication] Java Home: C:\PROGRA~2\APC\POWERC~1\JRE18~1.0_32017-03-02 19:41:26,124 [main] INFO - [application.PicardApplication] JVM: Java HotSpot(TM) Client VM (version: 25.31-b07)2017-03-02 19:41:26,124 [main] INFO - [application.PicardApplication] OS: Windows Server 2012 (x86)2017-03-02 19:41:26,124 [main] INFO - [application.PicardApplication] Time Zone: Europe/Helsinki2017-03-02 19:41:26,124 [main] INFO - [application.PicardApplication] PCBE dir: C:\PROGRA~2\APC\POWERC~1\agent2017-03-02 19:41:26,124 [main] ERROR - [application.PicardApplication] Can not read M11.cfg file:java.io.FileNotFoundException: m11.cfg (The system cannot find the file specified) at java.io.FileInputStream.open(Native Method) at java.io.FileInputStream. at java.io.FileInputStream. at com.apcc.m11.application.PicardApplication.verifyAndUpdateConfigFile(Unknown Source) at com.apcc.m11.application.PicardApplication.createPermanentStorage(Unknown Source) at com.apcc.m11.application.PicardApplication.main(Unknown Source)2017-03-02 19:41:26,124 [main] INFO - [application.PicardApplication] Created thePermanentStorage2017-03-02 19:41:26,139 [PcbeHSM-EventDispatcher] INFO - [AgentHSM.AgentHsm] State Change InitialState -> ActiveState2017-03-02 19:41:27,155 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:28,171 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:29,188 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:30,204 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:31,220 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:32,235 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:33,252 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:34,268 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false2017-03-02 19:41:35,283 [main] INFO - [application.PicardApplication] isStartupComplete() - returns: false
I do it recommendation for clear:
And after reinstall now all ok.
Thanks.
