Posted: 2021-06-30 08:17 PM . Last Modified: 2024-03-07 12:28 AM
Hello folks,
I did sth wrong.. I started up a totally fine working sua3000rmi2u, batt voltage about 52. But while startup I had some loads on it, and unplugged the mains before or during the battery check, it should have been a test 😞
Now its dead, no light on the display, nothing. Yes I replugged it all in as intended. Mains input capacitor is chirping a little, but thats it. Batt voltage fine, mains fine, but its dead. Powerchute, not previously installed, declines installation because of missing UPS (attached by USB).
I got some spares arround here, but only parts, like relais, capacitors and such.
Could some relais be stuck? If so, witch one?
Im deeply concerned about this as I need it and theres no money rigth now for an replacement..
Thans a lot for your help!
cheers!
Posted: 2021-06-30 08:18 PM . Last Modified: 2024-03-07 12:28 AM
ok, I found out it had been turned of in runtime calibration.. Thats the problem. Can this be reset?
thank you!
thank you!
