SUA2200 reporting it a Smart-UPS 500 and 24volt not 48volt
  • SUA2200 reporting it a Smart-UPS 500 and 24volt not 48volt
Posted: ‎2021-06-29 07:27 AM . Last Modified: ‎2024-03-12 03:41 AM
830
SUA2200 reporting it a Smart-UPS 500 and 24volt not 48volt,
below unit 1 is working fine ,, unit 2 is reporting it's a ups500
seems to be a logic prob, inverter fuction working on battery
wont switch to line reporting no volts (false)
i can't seem to change voltage with g +- in terminal
or model string with ^A +- in treminal, z no effect
sorry using linux no  powershute
is there a key combo in terminal
to change model string back to Smart-UPS 2200 ??
   sorry or the long post
[UNIT 1 sua2200] working fine
UPS Status: 08
Line quality: FF
Reason for last transfer to batteries: S
Self-Test Status: NO
Line Voltage: 122.4
Line Voltage Max: 122.4
Line Voltage Min: 121.6
Output Voltage: 122.4
Batt level percent: 100.0
Batt voltage: 55.35
UPS Load: 000.0
Line freq: 60.00
Runtime left: 0095
UPS Internal temp: 016.6
Dip switch settings: NA
Register 1: 00
Register 2: 00
Register 3: 00
Sensitivity: H
Wakeup delay: 000
Sleep delay: 090
Low transfer voltage: 106
High transfer voltage: 127
Batt charge for return: 00
Alarm status: 0
Low battery shutdown level: 02
UPS Name: 2200_1
UPS Self test interval: 336
UPS manufacture date: 11/16/04
UPS serial number: JS0447004854
Date battery replaced: 11/16/04
Output voltage when on batteries: 120
Nominal battery voltage: 048
Percent humidity: NA
Ambient temperature: NA
Firmware revision: 654.12.D
Number of external batteries installed: 000
Number of bad batteries installed: NA
UPS model as defined by UPS: Smart-UPS 2200
UPS EPROM capabilities string: uD43127130133136uA43108110112114uI43253257261265uM43225229233237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e47200153045607590oD13120oA13100oI33230240220oM13208s431HMLq4820205081114172023p483090180270360450540630000k4310TNr483000060120180240300360420E443336168ON OFF
The EPROM string is 286 characters long!
[UNIT 2 sua2200] reporting model 500
UPS Status: 10
Line quality: 00
Self-Test Status: OK
Line Voltage: 000.0
Line Voltage Max: 000.0
Line Voltage Min: 000.0
Output Voltage: 120.1
Batt level percent: 031.0
Batt voltage: 23.89
UPS Load: 000.0
Line freq: 60.00
Runtime left: 0029
UPS Internal temp: 013.9
Register 1: 00
Register 2: 00
Register 3: 00
Sensitivity: H
Wakeup delay: 000
Sleep delay: 090
Alarm status: 0
UPS Name:
UPS serial number:
Nominal battery voltage: 024
Firmware revision: FWD
UPS model as defined by UPS: Smart-UPS 500
This is outside the scope of APC/Schneider Electric Technical support but if anyone else wants to chime in and help and provide instructions to use at their own risk, please feel free to do so.
