Posted: 2021-06-28 09:34 AM . Last Modified: 2024-03-17 11:13 PM
I have mounted a new SRT5KXLI with 4 battery pack SRT192BP.
When i mount the 4 - th battery pack I have an error on display "Error B.08 - Contact Customer Support ". removed and pluged again but the error did not disappear. On web I have an critical alarm "1 Critical Alarm present - Battery general error for battery pack 4 " even i have removed the battery.
1.What this error means? "Error B.08 - Contact Customer Support ".
2. How can I remove the critical alarm "1 Critical Alarm present - Battery general error for battery pack 4 " - reboot and self test already done it.
Thank you
Hi Muresan,
In that case it is likely a hardware issue with the external battery pack. I would recommend you contact your local customer support team. Contact information can be found at https://www.apc.com/support
Liam
Hi Muresan -
Are you using an extension cable with your battery packs? Does the fault clear with battery pack 4 removed?
Liam
Hi Liam,
I am using the original connection without any extensions (see attachment). After removing the battery I have to click "acknowledge" on the display, but on web i still see the error :
""""2 Critical Alarms Present
Battery general error for battery pack 4.
Battery pack 4 disconnected.""""
BR Adrian
Hi Muresan,
Liam
