SRT2200XLA phase synchronization
Send InviteCancel
Posted: 2025-08-2411:05 AM
Does the on-line UPS SRT2200XLA synchronize its phase output to the input? If I understand it correctly, when the UPS operates in a regular "non-green" mode, the output of the UPS is fully isolated from the input and the attached load received AC current generated by the UPS.
In this case, is the phase output of the UPS synchronized with the input or is it independent?
