Enabling SmartConnect on APC SMC1500C UPS
  • Enabling SmartConnect on APC SMC1500C UPS
5060
142
esspaul
Crewman esspaul
Crewman
Posted: ‎2024-08-08 12:11 PM
4161
Can you explain specifically how I can manually enable SmartConnect Access on my APC SMC1500C UPS using the device's LCD screen?
My unit did not arrive with an operations manual.
Replies 7
Kirk
Posted: ‎2024-08-09 04:04 AM
4155
There is no direct method to connect to the APC Smart Connect Cloud Portal Service using just the LCD Menu.
You will require a smartphone and / or computer system. I have appended a video resource link for your review:
https://youtu.be/3_hc6gLeqZ4
Let me know if you have more questions. If not and this reply provided the solution please do mark it as so.
So it may help the next person asking the same. 👍
esspaul
Crewman esspaul
Crewman
Posted: ‎2024-08-09 04:31 AM
In response to Teken
4121
After having subscribed to the required 'Advanced Plan', the instructions on your website clearly state...
  • SmartConnect set to 'Enable - With Ctrl'. This can be manually enabled via the UPS device’s LCD screen. For more information, consult your UPS manual in the Documents section of the UPS Status page.
As I had previously mentioned, our newly purchased unit arrived without any such documentation. Is this documentation for our APC SMC1500C UPS available as a PDF for download somewhere? Anywhere?
Kirk
Posted: ‎2024-08-09 05:17 AM
In response to esspaul
If you’re logged into the APC Smart Connect Portal. Have you added the new device to your dashboard?!? Your hardware should have come with some paper documents and CD. Both of which more than likely refer you to the Smart Connect Cloud Portal Service.
Whether it provides more insight about the Enable I don’t know. Go through the LCD menu and see what the options are.
Let me know what you see on the LCD of the unit. Along with enrolling the new hardware into your dashboard.
RealPi88A
RealPi88A
Cadet
Posted: ‎2024-11-29 04:33 PM
3462
Having the same question. The manual says to change RC.0 to RC.1  on LCD display in order to enable remote access. However that simply will not work.
Kirk
Posted: ‎2024-12-02 04:28 AM
In response to RealPi88A
What exactly doesn’t work? The change in setting doesn’t stick when toggled from off to on?!?
_izy_
_izy_
Cadet
Posted: ‎2025-01-18 02:18 AM . Last Modified: ‎2025-01-18 09:02 PM
See the manual here: https://download.schneider-electric.com/files?p_Doc_Ref=SPD_AHUG-9ZSBHT_EN
Go to page 11, where it says “To enter configuration mode hold the MUTE and MENU buttons together for 2 seconds until the system emits a short beep and the display will flash to indicate the UPS has entered configuration mode.” Then see page 13 where you change the SmartConnect setting from rc.0 to rc.1
Reboot the UPS by powering it off and on, whereby your control panel will enable those options - to reboot remotely, etc.
  • rtfm
rspears1966
rspears1966
Cadet
Posted: ‎2025-08-26 05:16 PM
same issue, and no local LAN, although the UPS does ping.  just no HTTP(s).  SMC-1500.  seems very deceptive when the box clearly shows and states network compatible.  glad Amazon takes returns.  if you are buying this product thinking you can either control or monitor the UPS via IP, then buy something else.
