SMC3000RMI2U power input and charging watts?
Send InviteCancel
Posted: 2021-06-2811:22 AM. Last Modified: 2024-03-1505:42 AM
I'm looking at purchasing a SMC3000RMI2U for my homelab. I'm in Australia so on 240V single phase 50hz with standard home power outlets rated for 10A.
I see the SMC3000RMI2U is rated for 2.1kWatts max output and has a 16A input - I'm wondering what sort of amperage/watts is consumed when charging the batteries? Ultimately my question is if the max load of my homelab is 1kWatts can I safely power the SMC3000RMI2U using a 10A input rather than 16A?
