Runtime Exceeded not always trigger
  • Runtime Exceeded not always trigger
5060
142
Posted: ‎2021-07-08 06:00 AM . Last Modified: ‎2024-02-15 12:11 AM
846
hi APC,
I get a problem that the two APC Smart X 3000 UPS with management 2 running in redundancy mode. I set a bat file in Runtime Exceeded, but not always can trigger the bat file configured in Runtime Exceeded, it send PCNS shutdown signal to the Windows server instead of running the bat file.
Low battery duration: 30m
Outlet:
Power Off Delay: 600
Min Return Runtime: 900
Full path to command file: ...bat file (ping -n 900 127.0.0.1) (Note: prevent the server shutdown before complete execute the bat file configured in "Runtime Exceeded")
Duration: 900s
PCNS shutdown the server, but no execute the bat configured in Runtime Exceeded.
KKD3K2L0EdqaCYOIXuH0BQ%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpegKKD3K2L0EdqaCYOIXuH0BQ%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
Regards
Thanks...KEN
hi,
Called support, lower the low battery duration value to 2 minutes fix the problem.
Regards
Thanks...KEN
Have you reviewed Schneider Electric FAQ FA159586 and what is function does the bat file do?
hi,
Regards
Thanks...KEN
