Posted: 2021-06-28 08:44 AM . Last Modified: 2024-03-17 11:50 PM
OK, perfect. I will add AP9630 NMC in my cart, I have already bought SMT-1500IC.
Thank you.
Miguel
PS: Maybe SmartConnect capabilities was unnecessary because redundant with AP9630
SmartConnect is designed to communicate with the Schneider Electric Cloud to allow you to monitor the Smart-UPS and provides notifications. SmartConnect is not designed as a management tool. If you would like to configure the UPS remotely and command outlet groups on and off you will need to install a network management card. The AP9630 allows for monitoring and management of the UPS via the local network.
On 8/27/2018 4:51 PM, Miguel said:- to power on/off remote devices: the devices connected in group 1 must be managed together or separately ?
To power on/off the outlet groups you will connect to the NMC. The NMC allow the ability to turn on/off just group 1 or if command the main then all outlets are turned on/off. The groups have delays and those setting are also configure through the NMC.
On 8/27/2018 4:51 PM, Miguel said:I have a IP relay box already but sometimes mine hangs. I would like to use SMT1500IC to reset the power of the relaybox without access to my local computer.
As an example: if you connect the IP relay to group 1 and the local computer to the main you could power cycle group 1 to get it back on line. This would not affect the main so the local computer will remain up.
Thank you.
Miguel
