Posted: 2021-06-28 09:23 PM . Last Modified: 2024-03-15 12:33 AM
Please can someone tell me if the broadcast element of Powerchute Network Shutdown only affects computers that are registered to one network management card? i.e. I have three APC UPS devices, one in each server room. The servers in each server room are on the same subnet. I am concerned that a shutdown command from a ups on the 3rd floor will trigger the shutdown of servers located on the 6th, which has a different IP address but on the same subnet.
Martin
there wont a be a problem. the management card only will only sent unicasts for shutting down to those clients that are listed as Powerchute Network Shutdown clients on any particular management card.
[here is a link to an article that may help you understand a little more how this process works too|http://www.apcmedia.com/salestools/BKIR-6QWKC5_R0_EN.pdf]
i realize you arent connecting more than 50 computers but it explains how this stuff works like the broadcasts and all that.
hope this helps!
hope this helps!
