PowerChute Install.sh Failes with Java Error
  • PowerChute Install.sh Failes with Java Error
Posted: ‎2021-06-28 11:45 PM . Last Modified: ‎2024-03-14 01:20 AM
731
This is being setup on a Solaris Server. I am running the install.sh script from the /tmp directory and receiving this error. Any assist / suggesstions appreciated.
Copying jre to /opt/APC/PowerChute/jre ...
Extracting jre to /opt/APC/PowerChute/jre ...
./install.sh: /opt/APC/PowerChute/jre/jre150_13/bin/java: cannot execute
Invalid jre path.
Installation canceled.
Thanks Erasmus-
You got me pointed in the right direction. I needed to point to the existing Java libraries and not the default as coded in the script.
Erasmus_apc
Sisko Erasmus_apc
Sisko
Does this directory already exist prior to the install? Can you delete the entire default install path, if present, then run the install again and provide a screenshot of the error and also what files you have in the tmp directory along with the install file? Also can you explain how you got the files out of their original .bin or downloaded install file? Also try moving everything to another directory.
Thanks Erasmus-
