Posted: 2021-06-29 08:15 AM . Last Modified: 2024-03-12 03:11 AM
I have an 27" iMac with an operating system of OS X 10.9.2. There is no Power Chute currently for this MacIntosh operating system. I want to remove the cable that goes from the BE750G to the iMac computer USB for PowerChute because my iMac restarts all by itself for some appent reason and I am trying to narrow down the items connected to my computer. Is anyone aware of any problem that this will cause with the BE750G APC Backup UPS? If so, please advise.
relaxed4102
Posted: 2021-06-29 08:16 AM . Last Modified: 2024-03-12 03:11 AM
If your UPS is a Smart-UPS with a Network Management Card we offer PowerChute Network Shutdown. Your options if connected to a UPS via USB are Native Power Save or APCUPSD.
relaxed4102
If you do not use the energy saver option with the UPS you do not need the cable connected so it is fine to disconnect it.
Can I ask if you had the APCUPSD software installed on that iMac?
If you did, you can try removing it using the command below in Terminal.
sudo /sbin/apcupsd-uninstall
Reboot the iMac after doing this, and you should see the UPS in Energy Saver.
Hope this helps.
We downloaded the free version of 10.9.2 and after the upgrade attached Back-UPS to the system.We tested a few different Back-UPS and in each case Energy Save is available and works as expected.
As for your question about the cable, if you are not using Energy Save or as mentioned by john1712 APCUPSD then there is no reason for having the USB cable attached to the Back-UPS.
It happened again on Monday, May 12, 2014 @ 8:47am, my 27" iMac crashed again because the cable from the APC Backup UPS BE750G was plugged into the APC Backup UPS to the back of my 27" iMac USB port. APC does not support my operating system or OS X 10.9.2. So I unplugged the cable again from the USB port on the back of my 27" iMac. APC should not make a Backup UPS for MacIntosh if they can't support thr current operating system or OS X 10.9.2.
I filed a report with Apple again on the crash as follows:
Anonymous UUID: E721D4D9-CD2F-285D-F8C9-46AF5A0FADE3
Mon May 12 08:47:43 2014
panic(cpu 4 caller 0xffffff8022adbe7e): Kernel trap at 0xffffff8022dc4030, type 13=general protection, registers:
CR0: 0x0000000080010033, CR2: 0xffffff83cd180000, CR3: 0x0000000062c1707d, CR4: 0x00000000001606e0
RAX: 0xffffff80654850b0, RBX: 0x0000000000000000, RCX: 0xdeadbeefdeadbeef, RDX: 0xdeadbeefdeadbeef
RSP: 0xffffff83afebbd00, RBP: 0xffffff83afebbdb0, RSI: 0xffffff80654850e8, RDI: 0x0000000000000000
R8: 0x0000000000000000, R9: 0x00000000000001cf, R10: 0x0000000000000000, R11: 0xffffffffffffffff
R12: 0x0000000000000000, R13: 0xffffff80654850a0, R14: 0xffffff8065a08a98, R15: 0xdeadbeefdeadbeef
RFL: 0x0000000000010282, RIP: 0xffffff8022dc4030, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0xffffff83cd180000, Error code: 0x0000000000000000, Fault CPU: 0x4
Backtrace (CPU 4), Frame : Return Address
0xffffff83a64e5df0 : 0xffffff8022a22fa9
0xffffff83a64e5e70 : 0xffffff8022adbe7e
0xffffff83a64e6040 : 0xffffff8022af3376
0xffffff83a64e6060 : 0xffffff8022dc4030
0xffffff83afebbdb0 : 0xffffff8022dc3d37
0xffffff83afebbe20 : 0xffffff8022dc347b
0xffffff83afebbf30 : 0xffffff8022dc2ff4
0xffffff83afebbf60 : 0xffffff8022e3e157
0xffffff83afebbfb0 : 0xffffff8022af3868
BSD process name corresponding to current thread: esets_proxy
Mac OS version:
13C1021
Kernel version:
Darwin Kernel Version 13.1.0: Wed Apr 2 23:52:02 PDT 2014; root:xnu-2422.92.1~2/RELEASE_X86_64
Kernel UUID: E9CF78E2-1E9F-3B6F-81A4-FEE6C6D0E4D5
Kernel slide: 0x0000000022800000
Kernel text base: 0xffffff8022a00000
System model name: iMac13,2 (Mac-FC02E91DDD3FA6A4)
System uptime in nanoseconds: 1163539110539
last loaded kext at 930315616457: com.apple.driver.AppleIntelMCEReporter 104 (addr 0xffffff7fa4e75000, size 49152)
last unloaded kext at 1000870976320: com.apple.driver.AppleIntelMCEReporter 104 (addr 0xffffff7fa4e75000, size 32768)
loaded kexts:
com.eset.kext.esets_kac 600.00.91f01
com.eset.kext.esets_pfw 600.00.91f01
com.apple.filesystems.afpfs 11.1
com.apple.nke.asp-tcp 8.0.1
com.apple.driver.AppleBluetoothMultitouch 80.14
com.apple.driver.AppleHWSensor 1.9.5d0
com.apple.driver.AudioAUUC 1.60
com.apple.filesystems.autofs 3.0
com.apple.iokit.IOBluetoothSerialManager 4.2.3f10
com.apple.driver.AppleMikeyHIDDriver 124
com.apple.driver.AppleMikeyDriver 2.6.0f1
com.apple.driver.AGPM 100.14.15
com.apple.driver.ApplePlatformEnabler 2.0.9d1
com.apple.driver.X86PlatformShim 1.0.0
com.apple.driver.AppleHDA 2.6.0f1
com.apple.driver.AppleUpstreamUserClient 3.5.13
com.apple.GeForce 8.2.4
com.apple.iokit.IOUserEthernet 1.0.0d1
com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport 4.2.3f10
com.apple.driver.AppleBacklight 170.3.5
com.apple.driver.AppleIntelHD4000Graphics 8.2.4
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.AppleMCCSControl 1.1.12
com.apple.driver.AppleLPC 1.7.0
com.apple.driver.AppleSMCLMU 2.0.4d1
com.apple.driver.AppleIntelFramebufferCapri 8.2.4
com.apple.driver.AppleHWAccess 1
com.apple.driver.AppleThunderboltIP 1.1.2
com.apple.iokit.SCSITaskUserClient 3.6.6
com.apple.driver.AppleUSBODD 3.4.1
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0d1
com.apple.BootCache 35
com.apple.driver.XsanFilter 404
com.apple.iokit.IOAHCIBlockStorage 2.5.1
com.apple.driver.AppleUSBHub 666.4.0
com.apple.driver.AppleSDXC 1.5.2
com.apple.driver.AirPort.Brcm4331 700.20.22
com.apple.iokit.AppleBCM5701Ethernet 3.8.1b2
com.apple.driver.AppleAHCIPort 3.0.0
com.apple.driver.AppleUSBEHCI 660.4.0
com.apple.driver.AppleUSBXHCI 670.4.0
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleACPIButtons 2.0
com.apple.driver.AppleHPET 1.8
com.apple.driver.AppleSMBIOS 2.1
com.apple.driver.AppleACPIEC 2.0
com.apple.driver.AppleAPIC 1.7
com.apple.driver.AppleIntelCPUPowerManagementClient 216.0.0
com.apple.nke.applicationfirewall 153
com.apple.security.quarantine 3
com.apple.driver.AppleIntelCPUPowerManagement 216.0.0
com.apple.security.SecureRemotePassword 1.0
com.apple.driver.AppleBluetoothHIDKeyboard 170.15
com.apple.driver.AppleHIDKeyboard 170.15
com.apple.driver.IOBluetoothHIDDriver 4.2.3f10
com.apple.driver.AppleMultitouchDriver 245.13
com.apple.kext.triggers 1.0
com.apple.iokit.IOSerialFamily 10.0.7
com.apple.driver.DspFuncLib 2.6.0f1
com.apple.vecLib.kext 1.0.0
com.apple.iokit.IOAudioFamily 1.9.5fc2
com.apple.kext.OSvKernDSPLib 1.14
com.apple.iokit.IOAcceleratorFamily 98.14
com.apple.nvidia.driver.NVDAGK100Hal 8.2.4
com.apple.nvidia.driver.NVDAResman 8.2.4
com.apple.iokit.IOBluetoothHostControllerUSBTransport 4.2.3f10
com.apple.iokit.IOBluetoothFamily 4.2.3f10
com.apple.driver.AppleBacklightExpert 1.0.4
com.apple.iokit.IOSurface 91
com.apple.driver.X86PlatformPlugin 1.0.0
com.apple.driver.AppleSMBusController 1.0.11d1
com.apple.driver.AppleHDAController 2.6.0f1
com.apple.iokit.IOHDAFamily 2.6.0f1
com.apple.driver.AppleSMBusPCI 1.0.12d1
com.apple.driver.IOPlatformPluginFamily 5.7.0d10
com.apple.driver.AppleSMC 3.1.8
com.apple.iokit.IONDRVSupport 2.4.1
com.apple.iokit.IOAcceleratorFamily2 98.14
com.apple.AppleGraphicsDeviceControl 3.4.35
com.apple.iokit.IOGraphicsFamily 2.4.1
com.apple.driver.AppleThunderboltEDMSink 2.1.3
com.apple.driver.AppleUSBHIDMouse 180.9
com.apple.driver.AppleHIDMouse 180.9
com.apple.iokit.IOSCSIMultimediaCommandsDevice 3.6.6
com.apple.iokit.IOBDStorageFamily 1.7
com.apple.iokit.IODVDStorageFamily 1.7.1
com.apple.iokit.IOCDStorageFamily 1.7.1
com.apple.iokit.IOUSBMassStorageClass 3.6.0
com.apple.iokit.IOSCSIArchitectureModelFamily 3.6.6
com.apple.iokit.IOUSBHIDDriver 660.4.0
com.apple.driver.AppleThunderboltDPInAdapter 3.1.7
com.apple.driver.AppleThunderboltDPOutAdapter 3.1.7
com.apple.driver.AppleThunderboltDPAdapterFamily 3.1.7
com.apple.driver.AppleThunderboltPCIDownAdapter 1.4.5
com.apple.driver.AppleUSBMergeNub 650.4.0
com.apple.driver.AppleUSBComposite 656.4.1
com.apple.driver.CoreStorage 380
com.apple.driver.AppleThunderboltNHI 2.0.1
com.apple.iokit.IOThunderboltFamily 3.2.7
com.apple.iokit.IO80211Family 630.35
com.apple.iokit.IOEthernetAVBController 1.0.3b4
com.apple.driver.mDNSOffloadUserClient 1.0.1b5
com.apple.iokit.IONetworkingFamily 3.2
com.apple.iokit.IOUSBUserClient 660.4.2
com.apple.iokit.IOAHCIFamily 2.6.5
com.apple.iokit.IOUSBFamily 675.4.0
com.apple.driver.AppleEFINVRAM 2.0
com.apple.driver.AppleEFIRuntime 2.0
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.iokit.IOSMBusFamily 1.1
com.apple.security.sandbox 278.11
com.apple.kext.AppleMatch 1.0.0d1
com.apple.security.TMSafetyNet 7
com.apple.driver.AppleKeyStore 2
com.apple.driver.DiskImages 371.1
com.apple.iokit.IOStorageFamily 1.9
com.apple.iokit.IOReportFamily 23
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleACPIPlatform 2.0
com.apple.iokit.IOPCIFamily 2.9
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.corecrypto 1.0
com.apple.kec.pthread 1
Model: iMac13,2, BootROM IM131.010A.B05, 4 processors, Intel Core i7, 3.4 GHz, 32 GB, SMC 2.11f16
Graphics: NVIDIA GeForce GTX 680MX, NVIDIA GeForce GTX 680MX, PCIe, 2048 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF4), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.3f10 13477, 3 services, 23 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST3000DM001, 3 TB
Serial ATA Device: APPLE SSD SM128E, 121.33 GB
USB Device: USB 3.0 HUB
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Back-UPS ES 750G FW:908.W3 .D USB FW:W3
USB Device: USB 2.0 HUB
USB Device: Apple Optical USB Mouse
USB Device: Hub
USB Device: Apple USB SuperDrive
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: iMac, Apple Inc., 23.4
If anyone has any suggestion, please advise.
relaxed
Hi Relaxed,
Your computer crashed while running code in "esets_proxy" which is part of ESET Cyber Security. They seem to recommend uninstalling and reinstalling ESET:
https://forum.eset.com/topic/587-process-crash-in-esets-proxy-50110/
I hope that helps.
Does Powerchute work with OS X 10.10?
