Posted: 2021-07-01 03:01 AM . Last Modified: 2024-03-05 11:11 PM
Hi there,
I have the PowerChute Business Edition Agent running on a Linux system (CentOS 6.4).
In Linux there is postfix as smtp relay configured what works well and is used with other applications.
In PCBE there is no option to configure a SMTP server, I assume that localhost is used.
But PCBE does not send any e-mail via the localhost smtp!
Is my assumption correct that localhost is the default SMTP server?
Or is there any config which I have to use?
Also there is no option to send a test e-mail.
I use the configured event for "Self test initiated" for my tests.
Is there any other way to test the e-mail settings?
Best regards
Guenter
Hi again,
sometimes I believe that I need new glasses!
Finally I found the config for the SMTP server in the menu "Server Shutdown / System settings".
And now it is working as aspected!
Thanks for all
Guenter
Hi again,
Thanks for all
Guenter
