Posted: 2021-06-29 11:29 PM . Last Modified: 2024-03-12 12:49 AM
I have APC Smart-UPS-X 1500VA USB & Serial (APC-SMX1500RM2U-NOB). Insert UPS Network Management Card 2 (AP9631).
On web NMC2 i see No UPS Found. In log there event: UPS: The local network management interface-to-UPS communication not established. I have upgraded the NMC to the latest firmware. Also upgraded the UPS via USB to the latest firmware as well.
7CgUuYNN1EPLkU1UNEZZqA%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
Hi Tony,
You're welcome. Is there a device (temperature sensor, for example) plugged into Universal I/O port 1? Or something that shouldn't be there?
Depending on your answer, you should be able to press reset lost comm alarm option and/or reboot the management interface (can do this via Control->Network->Reset/Reboot too) to clear that error if it is temporary or shouldn't be there but if there is a "problem" then I need to understand further what is actually connected or not connected.
Hi Tony,
I thought we had an FAQ on this but I can't find it right this second. I can tell from your screenshot that the incorrect firmware application is loaded on your AP9631. If you look at the top of your screenshot, you'll see where it says Symmetra 3 phase application. This goes along with the application module name of 'sy3p.' Since you have a Smart-UPS, you need to have the Smart-UPS application loaded and 'sumx' application module.
You can address this with reloading the NMC firmware and the issue will correct itself. Go to this link (http://www.apc.com/shop/us/en/products/UPS-NMC-v6-5-0-for-Smart-UPS-with-AP9630-31-35-Critical-Revie...) and download the file and apply it.
If you need detailed instructions to apply the firmware and available methods, refer to this FAQ and any of the NMC2 options: http://www.apc.com/us/en/faqs/FA156047
Hi Tony,
