Posted: 2021-07-01 03:16 AM . Last Modified: 2024-03-05 11:01 PM
HTTP was used to work fine with internet explorer until I recently upgraded IE to version 9. The link "3-Phase Display" under UPS is not display in the IE page anymore. Is there a known compatability issue with IE9? How do I fix this problem? Thanks,
Posted: 2021-07-01 03:16 AM . Last Modified: 2024-03-05 11:00 PM
Apparently also Java is required for the Mimic (3-phase display) to be displayed. Can you verify java is installed and working properly with IE9?
Have you tried compatibility mode in IE9 by chance?
Yes, I tried compatibility mode. It worked once and then disappeared upon screen refresh.
It worked with Java enabled. Thanks, Angela.
