Network Air FM Main Module Firmware Upgrade?
  • Network Air FM Main Module Firmware Upgrade?
Posted: ‎2021-06-28 03:23 AM . Last Modified: ‎2024-03-18 04:42 AM
1139
I upgraded the network card firmware on my FM and am now constantly receiving the following alert:
"Informational - NetworkAIR FM: Firmware Compatibility: The networking firmware is newer than the main module firmware."
How do I upgrade the main modules firmware? It seems to be different from the network interface?
Posted: ‎2021-06-28 03:24 AM . Last Modified: ‎2024-03-18 04:42 AM
I am having this same issue.  I have downloaded the 6.24.0 firmware and I have access to the cooling units, but I need the instructions on how to perform the upgrade.
The e-mail address in my profile is the best place to send the instructions to.  Thanks in advance!
Replies 8
can you email me the download for this firmware module. I am totally confussed. Cathy
yes, please email me (profile email is fine) the instructions and file. Thanks!
Message was edited by: bvienneau
Erasmus_apc
Sisko Erasmus_apc
Sisko
If you would like I can personally e-mail you the procedure as well as the firmware file itself. E-mail in your user profile?
bvienneau,
I'm not familiar with this error, but is it possible that you pushed the application module bin before pushing the AOS bin file to the NMC when performing the upgrade? Whenever upgrading, you must always transfer the AOS bin file first, then the application module bin file.
-Mike
Erasmus_apc
Sisko Erasmus_apc
Sisko
The main module firmware for the FM unit is not located on the network card, but the FM motherboard. It must be loaded via serial cable. This requires the unit to be down for 10-15 minutes while the FW loads.
Do you have any services applied to this FM unit that you know of? Typically our field service techs can upgrade firmware for you if there is a service/preventative maintenance on the unit.
Erasmus_apc
Sisko Erasmus_apc
Sisko
Just sent; instructions and firmware .bin file.
Erasmus_apc
Sisko Erasmus_apc
Sisko
You are also having the same issue with the FM Main module as described by "bvienneau"?
If so, is the e-mail in your profile acceptable?
