Posted: 2021-06-28 03:22 AM . Last Modified: 2024-03-18 04:43 AM
Our data center has 2 Network Air FM's pumping into the same cooling duct but they weren't setup for load sharing. They're essential 2 individual systems currently unaware of each other. Knowing that each one has the capacity to cool our data center by itself, we'd like to setup the load and runtime sharing to cut costs. Is this something that I can do fairly easily myself? I noticed the installation manual points to setting the DIP switch settings for the group. Is this all I need to do or is there something else mechanically that may need to be changed?
Posted: 2021-06-28 03:23 AM . Last Modified: 2024-03-18 04:42 AM
hi
please see the attached document on how to accomplish what you are looking for.
if you need any further assistance or have any other questions on the procedure, you can also contact the APC Air team @ 888 695 6500.
hope this helps!
Posted: 2021-06-28 03:23 AM . Last Modified: 2024-03-18 04:43 AM
That worked perfectly. Thanks!
hi
hope this helps!
