MGE gallaxy 5000 80KVA , BATTERY CHARGING VOLTAGE RISE TO 806VDC
Send InviteCancel
Posted: 2021-06-2812:13 PM. Last Modified: 2024-03-1504:14 AM
I need help on what might be the solution as the MGE GALLAXY UPS BATTERY CHARGING VOLTAGE WENT TO 806VDC almost twice the designed voltage which is around 400 Vdc
