Posted: 2021-06-29 10:38 PM . Last Modified: 2024-03-12 01:14 AM
Our infrastructure is based on three hosts managed by a virtual vCenter hosted on host 1, just as powerchute virtual appliance which manages shutdown.
When powerchute sends shutdown signal to all hosts, host 2 is correctly switched off with all VM gently shutted down, host 3 remains in maintenance mode (even with VM's shutted down) while host 1 is shutdown having powerchute VM powered off without guest-shutdown.
It seems that vCenter cannot be correctly stopped and host 3 cannot be shutdown.
It's not a permission issue: we are having tests using directly administrator@vsphere.local to avoid any trouble using domain admins.
What can be wrong?
Thanks in advance.
The event logs shows
Please follow the instruction in Schneider Electric FAQ FA230514 to put PowerChute into debug mode. Then run a shut down test. After the test has completed follow the instruction in Schneider Electric FAQ FA241061 to gather the needed troubleshooting files and attach the file to this post.
If you are not comfortable with attaching the files to the post please contact local support and they will assist you with the troubleshooting.
