Information on New SMART-UPS Firmware Subscription Plan
  • Information on New SMART-UPS Firmware Subscription Plan
deees
Crewman deees
Crewman
Posted: ‎2024-01-02 05:12 AM
5131
I recently received a notification of a new firmware version for the AP964x NMC. I downloaded the firmware deployment package to start testing it.
I was surprised to discover that in order to upgrade the firmware I have to enroll the NMC in a subscription plan, ($60/year.) I have ~350 UPS that I manage.
I've contacted my APC account manager to try to understand the full ramifications of this change in policy.
I also want to know what this new policy wasn't communicated to customer early enough to budget for this new cost?
I have dozens technical questions I need to have answer to.
Has anyone else obtained detail information regarding this new policy?
Kirk
Posted: ‎2024-01-03 09:00 AM
5072
Unless something has drastically changed from APC you can simply download the required firmware and load the same either through USB, Serial, NMC. If its true firmware will be hidden behind a pay wall shame on APC and its time to move on to another hardware vendor!
Whether that be Eaton, Vertiv, Tripp Lite, CyberPower . . .
Replies 13
dpierce4776
Lt. Commander dpierce4776
Lt. Commander
Posted: ‎2024-01-02 08:54 PM
5097
We don’t subscribe to that. You can simply download it and go
Kirk
5073
deees
Crewman deees
Crewman
Posted: ‎2024-01-03 11:15 PM
In response to dpierce4776
5072
Thanks for responding.
Could you elaborate?
Do you mean you download the version 3.x firmware and install it without a subscription?
Or do you mean you remain on version 2.x and upgrade through the previous methods?
dpierce4776
Lt. Commander
Posted: ‎2024-01-04 09:24 AM
In response to deees
You should be able to download it from the web at either APC.com or SE.com. From there you can install it manually. Also APC makes data center expert which is a program that monitors all your APC devices. And will do other manufactures as well. they also have a website for getting DDF files for DCE free of charge so DCE can read and understand multiple devices. DCE also downloads and pushes out new firmware/
deees
Crewman deees
Crewman
Posted: ‎2024-01-04 10:35 PM
In response to Teken
5040
Teken,
I accidently mark your response as a solution.
If you read my response to my own question, I explain that something did change:
 - The new SNS tool and firmware require a subscription.
 - Keeping the current 2.x firmware will allow customers to continue with the previous method.
Sherminator
Sherminator
Cadet
Posted: ‎2024-01-06 05:59 AM
4970
We're facing the same situation. We run a bunch of Smart UPS 3000 with AP9630 (which is deprecated), so we want to upgrade to AP9640. Today I installed the first one, and now the SNS says "Activate license to update". First I would like to know: If we want to buy these licenses, which is the correct one? I found FWENMC3P-ST1Y-DIGI, but this seems to be just for Easy UPS, not for Smart UPS.
Posted: ‎2024-01-08 07:36 AM
In response to Sherminator
The Schneider Electric Network Management Card 3 Secure NMC System FAQ discusses the changes to firmware distribution and lists the subscription SKUs.
https://download.schneider-electric.com/files?p_Doc_Ref=SPD_HEPN-BFRL57_EN&p_enDocType=Brochure&p_Fi...
deees
Crewman deees
Crewman
Posted: ‎2024-01-09 01:37 AM
Shermintor,
Just continue to use the 2.x version: https://download.schneider-electric.com/files?p_Doc_Ref=APC_NMC3_SU_2506_EN&p_enDocType=Firmware&p_F...
APC has promised to continue to support this code train with security and reliability updates. I couldn't find a linkable FAQ for the statement, but the text from the PDF is: "There is no impact to the features or functionality of the Network Management Card. Customers can continue to download the NMC3 firmware v2.5 from www.apc.com/secure-nmc. This firmware will remain available to support product warranty; therefore, in the event of a critical vulnerability or a defect which impacts the operation of the Network Management Card, an update addressing the vulnerability or defect will be made available."
I only care about security patches and basic stability. I'm still trying to get APC to confirm whether the computer running the SNS Tool can manage UPS NMC's that are on a different subnet/VLAN/WAN site?
Sherminator
Sherminator
Cadet
Posted: ‎2024-01-10 12:40 AM
4901
Thanks so much for your support!
Upgrading to 2.5.0.8 worked, so for now we plan to stick on 2.x.
Chris_P
Crewman Chris_P
Crewman
Posted: ‎2024-01-10 08:36 AM
From a legal perspective you may find that if they do eventually stop you download FW unless you subscribe, you may have a case (depending on the country you are in).
If you need to update because the product is not working correctly as expected, then it is not a fully functioning product, as would be expected.
Sherminator
Sherminator
Cadet
Posted: ‎2024-01-12 02:46 AM
Thanks for replying!
To be honest: For the moment we're fine with AP9640 and Firmware version 2.x. But our next project will be without APC. Paying for software updates (on an already not so cheap product) is a no go for us.
frank.virtualizen
frank.virtualizen
Cadet
Posted: ‎2024-09-20 03:23 PM
APC has changed. They now require subscription for firmware updates (which often are included for the first year). Alternatively, you can purchase APC's AI Management Tool EcoStruxure IT Expert which includes firmware updates among many significant value propositions. Feel free to reach out to me for more information. We're an APC Elite Partner.
npereira
Crewman npereira
Crewman
Posted: ‎2025-03-06 12:26 PM
Hi, i need firmare version  AOS 2.5.0.8 , but i cant find it , do you have firmware ? do you can share ?
