Posted: 2021-06-28 09:25 AM . Last Modified: 2024-03-17 11:18 PM
lwmc%2FKrl%2FX4Mk%2BV4wDSbpw%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
When I turn on the UPS the fault light and the second battery light on.
Has anyone ever been in this situation?
Posted: 2021-06-28 09:26 AM . Last Modified: 2024-03-17 11:18 PM
If you find your UPS needs replacing.
Go to APC.com and select your country, then select “How to buy” take a look at the trade up option.
Rich…
Hi
The lights signify a BackFeed relay weld.
If possible I would braindead the ups ( remove utility power and disconnect the batteries for a minute or so and then reconnect) to see if this clears the fault, and then monitor the ups to see if it returns.
Regards
Matt
I tried but it didn't work,
the fault light blink and after a time the UPS emits an uninterrupted sound.
Raphael
Hi Raphael,
This would indicate that there is a hardware fault with the UPS and that it needs to be replaced. If the unit is under warranty I would suggest contacting your local tech support team for further assistance.
Liam
Ok, thanks!
Raphael
Rich…
