Errors messages PCNS Network VM Appliance
  • Errors messages PCNS Network VM Appliance
Posted: ‎2021-06-30 12:16 AM . Last Modified: ‎2024-03-11 04:12 AM
1508
I’m using the virtual appliance on a single Esxi licensed host. Can you advise on the three warnings shown in the screen shot, do I just need to edit the .ini file ( where is it on the virtual appliance) or are they not significant to operation ?
Tony
Posted: ‎2021-06-30 12:17 AM . Last Modified: ‎2024-03-11 04:12 AM
Thanks. I have those entries.
I will I’ll leave it as is, as you suggest the error is benign
tony
Replies 5
I suggest you run PowerChute Setup again in the web interface and select standalone VMware Host for the VMware Configuration. Then complete the remaining set up.
the pcnsconfig.ini file is in /opt/APC/PowerChute/group1. If you decide the edit the .ini file you should stop the PowerChute service first. The command is service PowerChute stop.
Thanks. Ran the setup again as standalone host. Exactly the same warnings. Must I edit the file or are they benign?
Edited ini file and same warnings. Check INI file those entries gone. Also restarted whole appliance . See screen shot
Is protection working ???
The error are benign.
This is what the ini file should look like
[HostConfigSettings]
VMware_connect_timeout = 10
VMware_read_timeout = 15
enable_custom_target_vm_migration = false
custom_target_hosts =
[HostDetails]
ConfigurationMode = Unmanaged
Server = 192.168.1.100
Server_Protocol = https
Server_PORT = 443
tony
