Posted: 2021-06-28 06:11 AM . Last Modified: 2024-03-18 02:38 AM
thank You so much for all team apc support before.
I have the problem with out unit APC. The problem have to share like on picture. Please info to solved problem that.
Thank you
The LED indicates the UPS is running on battery power not AC. If AC is present and the UPS does not stop running on battery you should
1) Turn off and unplug UPS from wall
2) Press and hold the OFF button again
3) You may see a quick flash of the LED's and you should hear an audible "click" from the UPS.
4) Plug UPS back into the wall and turn UPS back on
