  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Does PowerChute run command file with elevated privileges?
  • Communities
  • Does PowerChute run command file with elevated privileges?
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
rmrme_apc
rmrme_apc
Posted: ‎2021-07-01 03:04 AM
312
This was originally posted on APC forums on 5/5/2013
I've installed PowerChute Network Shutdown on my Windows 2008 R2 Hyper-v servers.  PowerChute is configured to run a batch file if the UPS is on battery for a certain amount of time.  This batch file is just a simple script to run PowerShell (as Administrator) and put all running VMs into a saved state.  PowerChute is then configured to shutdown the Hyper-V server after a certain time.
When I run this batch file manually by double clicking it, it prompts me to confirm that I want to run it.  If I right click it and choose to 'Run as administrator' there is no prompt for action.  I therefore need to be sure that PowerChute will run this batch file with elevated privileges - otherwise I'm concerned that it will just be sitting waiting for a response and won't actually run and put my VMs into a saved state.
I don't want to simulate a power failure to test this, therefore I'm hoping that someone can confirm whether or not PowerChute runs a command file as an elevated user?
Thanks in advance for any help and advice.
R
Posted: ‎2021-07-01 03:05 AM
This reply was originally posted by Bill on APC forums on 4/20/2018
The information will be found by opening the systems control panel and go to Administrative tool- Services. Then right click on PCNS1 - Properties - Log On.
Replies 3
This reply was originally posted by Bill on APC forums on 5/6/2013
PowerChute Network Shutdown runs scripts as an Admin. If for some reason you needed to you can change the user in the Windows PCNS Service. Click on Log On, select this account and you can change the user.
dennishu_apc
dennishu_apc
This was originally posted on APC forums on 4/18/2018
Hello Bill
I am trying to run remote shutdown script to shut down my other server remotely but script worked on my cmd terminal but not with powerchute.
I was trying to find the logon option you mentioned but couldnt locate it anywhere from the web interface or the installed folder, could you help advise how to access to the logon option to change the privileges?
Thanks a lot
Dennis
Additional options
