Posted: 2021-06-29 02:23 AM . Last Modified: 2024-03-13 04:19 AM
I was wondering if the UPS network cards (specifically AP9630) are assigned default IP addresses upon being reset? This is due to the console port being broken on one of our NMC's which I need to configure, I was hoping it would have a default IP I could http into.
Thank you.
I am not sure. It may set it to DHCP and allow the router to set the IP address for the NMC or it may not even touch the IP address. APC does have a utility called "Device IP Configuration Utility", v 5.0.2, available that will search your network for any NMCs on the network and, assuming the ID and Password are known or set to default, will allow you to access the NMC's web interface and change the card's settings.
Good luck!
Good luck!
