  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Critical - UPS: An input voltage or frequency problem prevents switching to bypass mode.
  • Communities
  • Re: Critical - UPS: An input voltage or frequency problem prevents switching to bypass mode.
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
belostenac
belostenac
Posted: ‎2022-10-11 01:45 AM
1
210
In the last few weeks, the UPS MGE Galaxy 3500 40 kVA very often logs the event: Critical - UPS: An input voltage or frequency problem prevents switching to bypass mode. After a few seconds/minutes the error disappears and the message appears: Informational - UPS: An input voltage or frequency problem no longer prevents switching to bypass mode.
I suspect the problem is with the input voltage, which I would say from the logs is too high (log file attached).
What should we pay attention to and is there anything we could do to prevent similar events?
al_buffington
Lieutenant JG al_buffington Lieutenant JG
Posted: ‎2022-10-11 06:18 AM
You are correct. This is likely due to the input voltage or frequency moving outside the acceptable range where bypass operation is supported but not enough to cause the UPS to transfer to battery operation. On the voltage side this is somewhere between +/- 10% and +/- 20% of the nominal input. The range of operation related to the frequency can be configured via the display (note: changes can only be made if the UPS output power is off). I believe that the default setting is +/- 10Hz but it can also be set for .1 Hz  or 3Hz. If your setting is something other than 10 then perhaps changing the setting could reduce the number of instances of the event.
When this event is active, the UPS would not be able to transfer to bypass if maintenance is required or if a fault were to occur which prevented the UPS running in normal operation.  Since this event is triggered by the utility voltage you would have to address this with either your site facilities personnel or with your local utility provider.
I hope this helps.
Reply 1
al_buffington
I hope this helps.
Additional options
