Posted: 2021-06-26 04:27 AM . Last Modified: 2024-03-19 01:30 AM
We continue to recieve the following event every few days, but are not able to identify the problem.
I have had APC support out for maintenance and they as well do not know the answer. All card firmwares are up-to-date.
Critical - Environment: Lost the local network management interface-to-external Environmental Monitor TH Sensor 2 (Temp Sensor at AH North Server Room) communication.
Justin
This is an AP9604S - Silicon DP300e Triple Chassis
885-6072 Rv. 1
Yes they tried that.
Justin
One other thing, after receiving that event, with in seconds a second event occurs.
Informational - Environment: Restored the local network management interface-to-external Environmental Monitor TH Sensor 2 (Temp Sensor at AH North Server Room) communication.
Welcome to APC Forum Justin.
What kind of APC product do you have on your end that gives this error? Is this attached to a UPS? We would appreciate if you could provide these information.
This unit is a Silcon DP340E
More Detail
Hardware Factory
Model Number: AP9617
Serial Number: NA0803008229
Hardware Revision: A10
Manufacture Date: 01/15/2008
MAC Address: 00 C0 B7 CB B5 21
Management Uptime: 41 Days 0 Hours 57 Minutes
Application Module
Version: v3.3.1
Date: 01/05/2007
Time: 15:27:04
APC OS (AOS)
Version: v3.3.4
Date: 01/05/2007
Time: 14:23:44
do you have a triple chassis with your silcon? also, if you do have a triple chassis, do you have any other smart slot cards inside of it? we would like to know the firmware revision of the triple chassis if you do have one as well.
i thought the FW version was printed on it but you can get it [this way|http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=9142]. is it a AP9604S chassis as well? that can be found on the bottom of it.
when APC was out there, did you try reseating the probe on the AP9612TH or reseating the entire card? also, you could try moving the AP9612TH to slot one i think..
can you provide the entire event log from the network management card?
you can use [these directions|http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=9321]. thanks
885-6072 Rv. 1
