Connect Battery Error
Send InviteCancel
Posted: 2021-06-2811:35 AM. Last Modified: 2024-03-1504:56 AM
I have an SMT750 circa 2010, I changed the batteries this year and now I'm getting the "Connect Battery" error. I get power to the plugs but only on AC, I took out the battery and I read 26V @14 Amps. I've fiddled with connectors to rule that out, I also took some contact cleaner to the battery connect at the back of the unit. I also tried a self test, but it won't perform one due to the battery error. Is there something I can do or do I pitch the unit?
