Configuration of the outletgroups through CLI possible?
  • Configuration of the outletgroups through CLI possible?
Posted: ‎2021-06-30 08:14 AM . Last Modified: ‎2024-03-07 03:20 AM
992
Ist it possible to configute this menu through cli?
W0Vyh2pXi6OxiUkSKK%2Bw6g%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.pngW0Vyh2pXi6OxiUkSKK%2Bw6g%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.png
It could not find the commands to reach this menu through cli (AP9630) in the manual. I need way to change this settings on dozens of UPS-Units. Logging in on each of them and clicking throgh the menus would take ours.
You can make the changes on one unit and then copy the section of the INI file to the other or you can making the changes using SNMP.
If you edit the section of the INI file and then copy it to other NMCs the NMC must have the same outlet group configuration. See FAQ 156117 for information on copying sections of the INI file.
[SwitchableOutletGroups]
; Outlet group settings on the UPS.
;   Name:           Text description (typically 16 ASCII characters maximum)
;   PowerOnDelay:   Delay before turning on (in seconds)
;   PowerOffDelay:  Delay before turning off (in seconds)
;   RebootDuration: Delay used to guarantee a minimum off time (in seconds)
;   MinRetRuntime:  Minimum runtime before turning on after shutdown (in seconds)
;   LoadShedConfig: Setting for load shed; 0 means disabled (default), all
;                   other settings should be reviewed through the web UI
;   LoadShedRunTimeRemaining:  Runtime remaining for load shed (in seconds)
;   LoadShedPowerFailDuration: Time on battery for load shed (in seconds)
Group1Name=Outlet Group 1
Group2Name=Outlet Group 2
Group3Name=Outlet Group 3
Group1PowerOnDelay=0
Group2PowerOnDelay=0
Group3PowerOnDelay=0
Group1PowerOffDelay=90
Group2PowerOffDelay=90
Group3PowerOffDelay=90
Group1RebootDuration=8
Group2RebootDuration=8
Group3RebootDuration=8
Group1MinRetRuntime=0
Group2MinRetRuntime=0
Group3MinRetRuntime=0
Group1LoadShedConfig=0
Group2LoadShedConfig=0
Group3LoadShedConfig=0
Group1LoadShedRunTimeRemaining=120
Group2LoadShedRunTimeRemaining=120
Group3LoadShedRunTimeRemaining=120
Group1LoadShedPowerFailDuration=1800
Group2LoadShedPowerFailDuration=1800
Group3LoadShedPowerFailDuration=1800
