Cannot Uninstall PowerCute Network Shutdown from Windows Server 2008R2
Showing results forΒ
Did you mean:Β
  • Cannot Uninstall PowerCute Network Shutdown from Windows Server 2008R2
Posted: β€Ž2021-07-08 11:33 PM . Last Modified: β€Ž2024-02-14 11:48 PM
2449
I am trying to update my Powerchute software and I cannot because it says I have to uninstall the version I have installed, well, that one doesn't work and there is no shortcut to uninstall and no files in the folders that are an uninstall.exe, how do I get rid of my current install?
Thanks.
Posted: β€Ž2021-07-08 11:33 PM . Last Modified: β€Ž2024-02-14 11:47 PM
please, need instructions to manually remove PCNS from 2008 R2. first it was saying .cfg file is missing i copied it from other server, now it says verify.dll is missing and i cant run delete copy or anything.
hank you
Replies 5
Hi Frankd91474, i will PM you the manual removal instructions for PCNS. It is possible thas if the files have been deleted the service could still be running and the registry keys could be there as well.
Thanks for the PM it worked!
can I have the PCNS removal instructions for win 2008 r2 as well? it seems the software stopped working and cannot start nor get uninstalled. I don't seem to be able to uninstall it via Control Panel either (ERROR: could not open 'C:\PROGRA~2\Java\jre6\lib\i386\jvm.cfg') nor update to the latest one (nothing happens when I start installer).
thank you.
never mind. I copied over Java\lib and Java\lib files from Windows 7 x64 to problematic Windows 2008 R2 (those folders were missing in Java directory for some reason) and was finally able to uninstall old Powerchute Network Shutdown successfully.
Now re-installing Java and installing the latest PowerChute Network Shutdown πŸ™‚
hank you
Β
