Can't get agent running. SMT1500
  • Can't get agent running. SMT1500
Posted: ‎2021-06-30 03:02 AM . Last Modified: ‎2024-03-08 05:01 AM
2377
I have purchased a new Smart-UPS 1500 LCD (SMT1500) and have it hooked up to a Windows 2003 SBS w/ SP2 via USB. I downloaded the Powerchute 9.0 (5 node) and installed all 3 modules (agent, server, console), however, I am unable to get the agent service to run. I tried uninstalling all of the java versions on the server and installed the latest version thinking that would help, and reinstalled the agent, but no luck. I also uninstalled Mcafee Antivirus Enterprise 8.7 thinking that was blocking it.
The service shows as starting, even if i change from automatic to manual. I can't stop it.
I also can't access the web interface through http://127.0.0.1:3052/
In C:\Program Files\APC\PowerChute Business Edition\agent, I see an error log that shows the following which lead me to believe it may be a java issue?:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x77bbb08c, pid=5952, tid=6052
# JRE version: 6.0_19-b04
# Java VM: Java HotSpot(TM) Client VM (16.2-b04 mixed mode windows-x86 )
# Problematic frame:
# C [msvcrt.dll+0x1b08c]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0baa2c00): JavaThread "USB_UPS_DetectTimer" daemon [_thread_in_native, id=6052, stack(0x0cd00000,0x0ce00000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x005f33ce
Registers:
EAX=0x005b1fd8, EBX=0x005f33ce, ECX=0x00030002, EDX=0x000033d0
ESP=0x0cdff834, EBP=0x0cdff850, ESI=0x005c33cc, EDI=0x00000000
EIP=0x77bbb08c, EFLAGS=0x00010246
Message was edited by: ss911der
No problems doing the system file checker.
The debug file in the apc agent folder shows the following:
Fri Jan 28 18:01:04 EST 2011: [MicroLinkDeviceTranslator.()]- added MicroLinkOutletSystem data model to DataModelRegistry
Fri Jan 28 18:01:04 EST 2011: [MicroLinkDeviceTranslator.()]- added UPSCapabilities data model to DataModelRegistry
Fri Jan 28 18:01:04 EST 2011: [MicroLinkBatterySystem.()]- There was an error while querying the device for FQUNs: com.apcc.m11.arch.CommunicationException: MicroLink engine has not been inited yet.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Normal Energy Usage Startup.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Country: US
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Weight Measurement being used: Imperial
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- User has supplied their own data: false
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Reporting Start Date: Wed Jan 26 00:00:00 EST 2011
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Reporting End Date: null
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- PCBE Install Date: Wed Jan 26 00:00:00 EST 2011
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- PCBE Agent last contacted APC Energy Usage Web Service on Date: Wed Jan 26 00:00:00 EST 2011
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- Error retriving Energy Usage Variable 'WebServiceURL' from Permanent Storage.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- ConfigEntry not found: EnergyUsage.WebServiceURL
- Fri Jan 28 18:01:05 EST 2011:Critical Exception class com.apcc.m11.arch.storage.StorageEntryException:ConfigEntry not found: EnergyUsage.WebServiceURL On Thread Thread[PCBE Agent Main Thread,5,main] Caught at EnergyUsageReporting.readFromPermanentStorage()[:]
Thrown at HashPermanentStorage.readData()[:]
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.configureWebServiceVariables()]- Setting Default (EnergyUsageWebServiceURL): Web Service URL: http://updates.apc.com/pcbe/energyusage/GetPCBEInfo.cfm?Country=US
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- Error retriving Energy Usage Variable 'WebServicePCBESleepSeconds' from Permanent Storage.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- ConfigEntry not found: EnergyUsage.WebServicePCBESleepSeconds
- Fri Jan 28 18:01:05 EST 2011:Critical Exception class com.apcc.m11.arch.storage.StorageEntryException:ConfigEntry not found: EnergyUsage.WebServicePCBESleepSeconds On Thread Thread[PCBE Agent Main Thread,5,main] Caught at EnergyUsageReporting.readFromPermanentStorage()[:]
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.configureWebServiceVariables()]- Setting Default (EnergyUsageWebServicePCBESleepSeconds): Amount of sleep time between contacting APC Web Service: 2628000 Seconds.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- Error retriving Energy Usage Variable 'WebServiceRetrySleep1Seconds' from Permanent Storage.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- ConfigEntry not found: EnergyUsage.WebServiceRetrySleep1Seconds
- Fri Jan 28 18:01:05 EST 2011:Critical Exception class com.apcc.m11.arch.storage.StorageEntryException:ConfigEntry not found: EnergyUsage.WebServiceRetrySleep1Seconds On Thread Thread[PCBE Agent Main Thread,5,main] Caught at EnergyUsageReporting.readFromPermanentStorage()[:]
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.configureWebServiceVariables()]- Setting Default (EnergyUsageWebServiceRetrySleep1Seconds): APC Web Service sleep time retry #1: 600 Seconds.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- Error retriving Energy Usage Variable 'WebServiceRetrySleep2Seconds' from Permanent Storage.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- ConfigEntry not found: EnergyUsage.WebServiceRetrySleep2Seconds
- Fri Jan 28 18:01:05 EST 2011:Critical Exception class com.apcc.m11.arch.storage.StorageEntryException:ConfigEntry not found: EnergyUsage.WebServiceRetrySleep2Seconds On Thread Thread[PCBE Agent Main Thread,5,main] Caught at EnergyUsageReporting.readFromPermanentStorage()[:]
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.configureWebServiceVariables()]- Setting Default (EnergyUsageWebServiceRetrySleep2Seconds): APC Web Service sleep time retry #2: 1800 Seconds.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- Error retriving Energy Usage Variable 'WebServiceRetrySleep3Seconds' from Permanent Storage.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.readFromPermanentStorage()]- ConfigEntry not found: EnergyUsage.WebServiceRetrySleep3Seconds
- Fri Jan 28 18:01:05 EST 2011:Critical Exception class com.apcc.m11.arch.storage.StorageEntryException:ConfigEntry not found: EnergyUsage.WebServiceRetrySleep3Seconds On Thread Thread[PCBE Agent Main Thread,5,main] Caught at EnergyUsageReporting.readFromPermanentStorage()[:]
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.configureWebServiceVariables()]- Setting Default (EnergyUsageWebServiceRetrySleep3Seconds): APC Web Service sleep time retry #3: 3600 Seconds.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Duration since PCBE Agent last contacted APC Energy Usage Web Service (Days): 2
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Duration till PCBE Agent next contacts APC Energy Usage Web Service (Days): 27
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting.()]- Duration since Agent last contacted APC Energy Usage Web Service has not expired. Therefore not contacting Web Service as part of startup.
Fri Jan 28 18:01:05 EST 2011: [EnergyUsageReporting$APCEnergyUsageWebServiceChecker.run()]- PCBE Agent Energy Usage Web Service Checker Sleeping 2390335000 Milliseconds (27 Days) before contacting APC Energy Usage Web Service and checking for updates.
Fri Jan 28 18:01:06 EST 2011: [MicroLinkSlaveMonitorClient.()]- Version: 22(78EA31685F1CABBA2CADAF470A3DD69B)
Fri Jan 28 18:01:06 EST 2011: [Logger.error()]- USBTranslator.openDevice() - Failed: com.apcc.m11.components.MicroLinkPowerSource.protocols.usb.DeviceOpenException: Device ID reference is null
Fri Jan 28 18:01:11 EST 2011: [IndependentPowerSource.get()]- get(.3.1.1.1)com.apcc.m11.components.MicroLinkPowerSource.Exceptions.NotInitializedException
Fri Jan 28 18:01:11 EST 2011: [MicroLinkSwitchedOutletGroup.()]- Could not initialise 'theOutletGroup' with: SOG1
Fri Jan 28 18:01:12 EST 2011: [BypassReasonState.processReasonByStatusRegister()]- Duplicate event or Invalid bitmask value for UPSStatus_BF
Replies 10
Registers:
If you have your OS install CD handy you may want to try a repair installation after you've removed Java, PCBE and run the registry cleaner.
So, I tried replacing the .dll file in windows\system32 with a newer version, but with no success. Anyone know what the deal is with my situation?
Thanks!
Ok, I will run SFC and see what it finds. Thanks
I've installed the same version it was tested with, and used the APC java application to switch between different versions (latest version) of java. No luck. Any other suggestions? I am not giving up.
Do I need to open up a ticket with phone support? I need to get this resolved.
I ran across that as well, but no luck.
I tried firefox as well as IE. The agent service has a problem starting, so I didn't even bother trying on another pc.
I have tried searching thru Google about this problem and I've chanced upon a person who said that what he did is uninstall JVM and run CCleaner. He then restarted the machine and reinstalled Java and the application that he intent to use.
