Assistance For Smart UPS SUA1000XL problem
  • Assistance For Smart UPS SUA1000XL problem
Posted: ‎2021-06-28 08:43 AM . Last Modified: ‎2024-03-17 11:51 PM
1333
My UPS creating problem with charging and load i have installed two batteries. I using its after three month of shutdown.  I am using it from Last two years.
Some time battery charging indicators blink some time remains static.
Its making too much clicking sound. Its also make clicking sound even it totally poweroff. Red wire connected with positive terminal and black wire to negative terminal, while both batteries -/+ connected to each other.
Please help guys.
Junaid
Below is my battery connection. PFlR6IFkTDXkiDD733f3YQ%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpegPFlR6IFkTDXkiDD733f3YQ%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
Dear Liam,
thanks again. The UPS start after some time. but i don't understand if battery get low how it power on after some time, how its possible.
Should i change my ups or you will do any recommendations.
junaid
Replies 5
Hi Junaid,
The flashing battery bar graph indicates that the calculated runtime is within 2 minutes of your low battery setting. We do not support using 3rd party batteries with these units. Since you are using large non-APC external batteries, the UPS will likely never calculate the runtime properly. If you are not using any shutdown software this is more of a cosmetic issue than anything else. The UPS will still run on battery until they are fully discharged.
As far as the clicking sound - I couldn't hear it in the video. Does it correspond with any indicators on the UPS?
Liam
Dear Liam
Many Many thanks for your kind reply.
Basically in my origin Pakistan we don't easily facilities for good betters or apc recommended
Some one advise me that is software issue It need to be reinstall.
I do self test now its better than before. Regarding clicking sound its show voltage Indicator avr low and high
Will let you know if some thing else happened
Junaid
Dear friend
Now ups completely shutdown in an hour after power failure
Not powering on
Junaid
Hi Junaid,
The UPS requires a functioning battery in order to turn on. If the battery is completely dead, it is possible that it may be preventing the UPS from turning on. You also mentioned that the AVR light was on earlier - If the input voltage is too high or too low, that could also prevent the UPS from turning on. You may want to wait until power stabilizes and then try again.
Liam
Dear Liam,
junaid
