Posted: 2021-06-26 05:58 AM . Last Modified: 2024-03-19 12:26 AM
Please, I am not sure if MGE Galaxy 300 G3HTBAT1 Cabinet comes pre-installed with battery modules and has other installation accessories?
Clarification will be highly appreciated.
Thanks.
My mistake. Did some more double checking. Here is the answer I got:
The G3HTBAT1 battery cabinet is populated with batteries and can only be used with a 10kVA UPS. Here is the tech spec doc for more info. We are not sure what you are referring to when you ask about accessories.
See attached for the spec sheet.
I only see this as a battery frame with no batteries included. I don't see anything included with it beyond the cabinet itself.
The only other nice piece of documentation I found was dealing with runtimes -> http://www.apcmedia.com/salestools/COCR-92JM24/COCR-92JM24_R0_EN.pdf
Thanks for your reply. I have been searching for the cabinet with pre-install battery modules. Anyone knows hat this part number may be. I need the cabinet with pre-installed batteries or the part no. of the batteries meant to be installed into the G3HTBAT1 cabinet.
Any contribution will be appreciated.
Thank you.
