Send InviteCancel
Posted: 2021-07-0806:04 AM. Last Modified: 2024-02-1512:08 AM
Hi Shampad,
There are a few steps required before HTTPS will work - specifically it needs to be enabled in the interface under "Configuration --> Network --> Web -> Access". By default the card will create a self-generated certificate, and will be configured for TLS 1.1 - depending on your environment and browser configuration you might need to change the "minimum protocol" to TLS 1.2.
Hi Shampad,
