APC AP9211 Password Reset
  • APC AP9211 Password Reset
145
Posted: ‎2021-06-29 08:58 AM . Last Modified: ‎2024-03-12 01:30 AM
15884
I've recently purchased a used APC AP9211 unit with an AP9606 Web/SNMP Management Card installed and am unable to get the password reset procedure documented at http://www.schneider-electric.us/en/faqs/FA156075/ to work. I am working on multiples of these and just got another identical unit to work just fine five minutes prior so I'm not sure what the problem could be unless it's a difference in firmware versions. The serial number of the unit is WA0014004210. Can someone provide me with a password to access the unit so that I can reset the unit to defaults?
Replies 73
  • « Previous
    • 1
    • 2
  • Next »
Posted: ‎2021-06-29 09:03 AM . Last Modified: ‎2024-03-12 01:22 AM
I just changed the password from my admin account and now I can't login anymore. Not with the old and not with the new PW.
Need to reset, AP9606  JA0236007302
Andre
  1. Use lower case apc for user name in either hyper-terminal or telnet (won't work via the web)
  2. Use the following for password 12:758QI9<>B (any letters are capitalized)
  3. You will then have to log in again but use lower case apc for both user name and password
Posted: ‎2021-06-29 09:04 AM . Last Modified: ‎2024-03-12 01:21 AM
Hi Bill,
just made Telnet to the system and did the following:
telnet 192.168.1.112
User Name : apc
Password  : 12:758QI9<>B
User Name : apc
Password  : apc
User Name : apc
Password  : apc
Connection lost.
Was the way right ? It even doesn't work with the webinterface after first telnet.
Posted: ‎2021-06-29 09:04 AM . Last Modified: ‎2024-03-12 01:18 AM
I am in a similar situation as I have taken over a project from a retiree.  My S/N is WA0012010746
any help would be appreciated
B-DoubleE_apc
Commander B-DoubleE_apc
Commander
Posted: ‎2021-06-29 09:04 AM . Last Modified: ‎2024-03-12 01:17 AM
Hi Greg,
Backdoor password for that serial is 133;9<^I9:<>
Thank You
Mike
Same issue here WA0112001346
Hello,  If possible I would like to get the backdoor password for an AP9211 that I have:
MODEL: AP9211
SERIAL: BA0130001829
Thank You!
Hi Matt!
Can you help me? Please Sent password for AS1643170501
Posted: ‎2021-06-29 09:05 AM . Last Modified: ‎2024-03-12 01:17 AM
Hi
Use the following for password 12479<^I9;<> (any letters are capitalized)
Please be advised that this unit is passed end of life and no longer supported by Schneider Electric.
Posted: ‎2021-06-29 09:05 AM . Last Modified: ‎2024-03-12 01:16 AM
Hi
Use the following for password 124<7?II9;>< (any letters are capitalized)
Hi Dmitriy,
What is the model number of the product you require a password for?
Hi, Bill!
Product Smart-UPS SRT 6000
This thread is for AP9610 and AP9611 not SRT Smart-UPS. To reset the password of the network card installed in a SRT Smart-UPS please see Schneider Electric FAQ FA156075
I have a ap9606 card in a ap9211 with serial number JA0250014244 what is the password I can use to the reset card.
Thank you in advance for your help.
12221222ras
12221222ras
Cadet
Posted: ‎2022-02-07 11:07 AM
In response to BillP
3485
Hi I have two  APC ap7900 serial number 5a1037e03199 & ZA11115014340 can I please get recovery passwords? Thanks.
TonKei
Lieutenant TonKei Lieutenant
Lieutenant
Posted: ‎2022-02-07 10:03 PM
In response to 12221222ras
3479
Hi
The units do not have a recovery password as such, but there is a FAQ document detailing the password recovery process
-> https://www.apc.com/us/en/faqs/FA156075/
I believe the AP79xx units are equipped with an NMC1, so I would advise looking to that part of the document.
Best regards
Tonny
FredP
FredP
Cadet
Posted: ‎2022-07-30 06:33 AM
In response to TonKei
Got two second hand AP9212 with the 9606 Management cards for home.
No luck with all published reset methods.
If you could help.
Both are Model AP9212 / AOS 254 / APP ms210 / p/n 640-0823G
s/n are
0100000003653075   WA0043001840 00c0b7a28cf0
0100000003618271   WA0040017542 00c0b7a2adf8
Any help possible ?
Fred.
Philwil
Philwil
Cadet
Posted: ‎2024-09-17 02:31 PM
In response to B-DoubleE_apc
Hello I have a similar problem with password reset
User Name : apc
Password : ******
WA0034001942
NickyDoes
NickyDoes
Cadet
Posted: ‎2024-10-24 08:01 AM
Could you share the backdoor password for serials:
WA0026018995 (sticker on AP9211)
WA0026013833 (obtained with user: apc / pass: apc -s)
NickyDoes
NickyDoes
Cadet
Posted: ‎2024-10-24 08:10 AM
Hello Bill,
I have an AP9211. The serial on the bottom reports WA0026018995
The serial number on the AP9606 smart slot card that is labeled AP9211 is: WA0026013833. This is also the serial reported by signing in via RS-232 with username `apc` and password `apc -s`
Could you provide the recovery password for this unit?
ynot
ynot
Cadet
Posted: ‎2024-10-28 06:39 PM
I just purchased a used AP9211 with SN JA0208007251 for my home CCNA study lab. What is the backdoor password for this device? Thanks, in advance.
Bryce_Computers
Bryce_Computers
Cadet
Posted: ‎2025-03-12 03:17 PM
If you could provide the backdoor password that would be great.
AP9606 - WA0023010371
and
AP9606 - WA0020007389
Thank You.
Chrislenton
Chrislenton
Cadet
Posted: ‎2025-07-06 10:31 AM
Hello,   can you please help me with the backdoor password for device serial ZA1521012922.
Chris
  • « Previous
    • 1
    • 2
  • Next »
