AP9641 reboots every 10 minutes
  • AP9641 reboots every 10 minutes
MikeH
Crewman MikeH
Crewman
Posted: ‎2022-06-02 06:57 AM
8867
Have been going around for a while trying to get this management card to stop doing the watchdog timer reboot.  I've set it to use static IPs as well as DHCP and can't seem to find any way to make it stop.  How do I resolve this, or disable the watchdog timer? Firmware has been updated to v2.2.0.1.
Matt-B
Lieutenant JG Matt-B Lieutenant JG
Lieutenant JG
Posted: ‎2022-06-02 09:44 AM
4
8849
We've seen restarts like this on cards that were at one time running firmware version v1.6.1.1 or earlier. To fix it, after upgrading to v2.2.0.1 you can download the config.ini file, then format the NMC using one of two methods:
  • Boot loader: Connect to the NMC3 via the Console Port.  Restart the NMC3.  Within 4-5 seconds of restart, press the <enter> key to interrupt the boot loader.  From the BM> prompt, type “format”.  Once the format is complete, type “reset”, the NMC3 should restart and boot normally.
  • Reset button: Press and hold the reset button located at the front of the NMC3, for at least 20 seconds, or until the Status LED begins to blink orange.  Allow the NMC3 to restart.
After the format, you can upload the saved config.ini file to preserve the settings that the format erased. For simplicity sake, I'd recommend using the reset button to format.
Replies 5
Matt-B
Lieutenant JG
4
8850
MikeH
Crewman MikeH
Crewman
Posted: ‎2022-06-02 11:58 AM
In response to Matt-B
8844
Thanks that did the trick! Actually this UPS is on a remote site so didn't have physical access.  I was able to accomplish the same thing though by going in via SSH and doing a format command then a reboot.
Shaun
Commander Shaun Commander
Commander
Posted: ‎2022-06-03 01:34 AM
In response to MikeH
2
8824
Hi @MikeH,
The easier option was left out intentionally - we've noticed that if the affected file is deleted, or the card is formatted online (the method you've used while the card is running) - sometimes the issue returns, sometimes it doesn't.
Just something to keep in mind if the issue returns, or for anyone else searching this topic.  If the shortcut works - great.  If it comes back, it may need a heavier touch.
  Shaun
J-E-1984
Ensign J-E-1984
Ensign
Posted: ‎2022-09-13 09:41 AM
In response to Shaun
Seems we're in "Heavier Touch" areas as we have the same issue...
Tafadzwa
Lt. Commander Tafadzwa
Lt. Commander
Posted: ‎2024-04-26 12:57 AM
Hi @MikeH
I have several UPSs at remote Sites and I am also facing the same issue with this network card.
Is the resolution to this problem still requiring physical access to the UPS?
Connecting Devices!
