Share Your Feedback โ€“ Help Us Improve Search on Community!
AP9630 - The Application Was Not Able to Load
Showing results forย
Did you mean:ย
  • AP9630 - The Application Was Not Able to Load
VincentDuvernet
Crewman VincentDuvernet
Crewman
Posted: โ€Ž2022-03-29 09:02 AM
26168
Hello
I'im stuck with the web server message "The Application Was Not Able to Load".
The AP9630 card is inserted into a Smart-UPS 2200 (SRT2200XLI). This AP9630 was inserted into other UPS with the same problem as long as I remember.
Prior to this message using firmware 6.9.6 it was a slightliy different message "Application is not compatible with the AOS".
I can connect using COM3 or SSH without any problem.
NMC firmware Update Utility don't work:
- FTP "Could not retreive cofiguration configuration file via this method, please recheck settings"
- SCP "Resume not supporter for SCP transfers"
I tried without success:
resetToDef โ€“p keepip
format
I put files using ftp commands. I was able to upgrade to 7.0.4 but the Stat is still: P+ N4+ N6+ A-
Here's the about command :
E000: Success
Hardware Factory
Model Number: AP9630
Serial Number: ZA1526020265
Hardware Revision: 05
Manufacture Date: 06/22/2015
MAC Address: 00 C0 B7 EB DC 61
Management Uptime: 0 Days 0 Hours 18 Minutes
Application Module
Version: v7.0.4
Date: Jul 26 2021
Time: 15:26:26
APC OS(AOS)
Version: v7.0.4
Date: Jul 26 2021
Time: 15:26:26
APC Boot Monitor
Version: v1.0.9
Date: Mar 27 2019
Time: 16:23:06
What can I do ?
Vincent
brendanmain
Crewman brendanmain
Crewman
Posted: โ€Ž2022-06-24 08:24 PM
In response to VincentDuvernet
25663
this worked for me 6.6.4 firmware upgrade to new 7.0.4 firmware broke network management card application
downgrade to old v5.x firmware using apc firmware update utility 1 which uses FTP, then upgrade to latest firmware using apc firmware update utility 2
https://www.se.com/au/en/product/AP9631/ups-network-management-card-2-with-environmental-monitoring/
Replies 11
TonKei
Lieutenant TonKei Lieutenant
Lieutenant
Posted: โ€Ž2022-03-29 09:28 AM . Last Modified: โ€Ž2022-03-29 09:29 AM
26128
Hi Vincent
This could look like an issue caused by the application module not being loaded correctly during a firmware upgrade.
My best guess here would be to try doing the upgrade manually, as detailed in the FTP/SCP section of this document:
-> https://www.apc.com/ie/en/faqs/FA156047/
You might be able to just skip the bootmon and AOS and jump straight to the APP, but for good measure I would go by the numbers and refresh all 3.
Best regards
Tonny
  • application module
  • firmware
  • nmc2
VincentDuvernet
Crewman
Posted: โ€Ž2022-03-30 01:38 AM
In response to TonKei
26086
This AP9630 card don't have an USB port ๐Ÿ˜ž
I'm unable to access the BootMonitor. I have the green/orange LED blinking quickly but using TeraTerm with 57600/8bits/none/1bit show nothing. Did I do something wrong ?.
TonKei
Lieutenant
Posted: โ€Ž2022-03-30 02:08 AM
Hello Vincent
The console/serial port on this card is the mini jack port, and to use it, you Will need the console cable that came with the card originally.
That being said, I gathered from the information you gave in your previous post, that you have FTP access to the card?
If so, I still suggest following the procedure for using FTP to upgrade the firmware, as detailed in the link from my previous post.
Best regards
Tonny
brendanmain
Crewman brendanmain
Crewman
25664
VincentDuvernet
Crewman
Posted: โ€Ž2022-08-10 02:25 AM
In response to brendanmain
Thanks it works ๐Ÿ™‚ it's back to life now
cabricharme
Crewman cabricharme
Crewman
Posted: โ€Ž2023-03-21 03:47 PM
24024
Can't seem to be able to follow this solution - would anyone have a word of wisdom for me?
AP9630 NMC with 5.0.3 firmware on SUA1500RM2U UPS. Attempted to use "Network Management Card v7.0.8 Firmware Executable for Smart-UPS with AP9630/31" to upgrade the firmware, got "unable to update", and then the web UI wouldn't open:
Error: The application was not able to load.
You are attempting to access an APC device.
There was a problem loading the application. Please login to the device via telnet for more details.
Can access the CLI (telnet) and FTP.
American Power Conversion               Network Management Card AOS      v5.0.3
(c) Copyright 2009 All Rights Reserved
Name      : **********                                Date : 03/21/2023
Contact   : ******                                    Time : 15:35:14
Location  : **************                            User : Administrator
Up Time   : 0 Days 0 Hours 56 Minutes                 Stat : P+ N+ A-
apc>about
E000: Success
Hardware Factory
Serial Number:          ZA102501****
Manufacture Date:       06/16/2010
MAC Address:            00 C0 B7 D7 3C A2
Management Uptime:      0 Days 1 Hour 5 Minutes
Application Module
Version:                v1.0.9
Date:                   Mar 27 2019
Time:                   16:23:06
APC OS(AOS)
Version:                v5.0.3
Date:                   Aug  4 2009
Time:                   13:12:44
APC Boot Monitor
Version:                v1.0.0
Date:                   Oct  8 2008
Time:                   16:03:02
apc>dir
E000: Success
--wx-wx-wx  1 apc      apc      2122752 Aug  4 2009 apc_hw05_aos_503.bin
drwxrwxrwx  1 apc      apc            0 Jan  1 2000 db/
drwxrwxrwx  1 apc      apc            0 Jun 16 2010 ssl/
drwxrwxrwx  1 apc      apc            0 Jun 16 2010 ssh/
drwxrwxrwx  1 apc      apc            0 Jun 16 2010 logs/
drwxrwxrwx  1 apc      apc            0 Jun 16 2010 sec/
drwxrwxrwx  1 apc      apc            0 Jun 16 2010 dbg/
drwxrwxrwx  1 apc      apc            0 Aug 23 2010 scg/
It seems that from here I need to manually FTP either the 5.x or 6.x firmware to the NMC and upgrade it that way (still unclear how, exactly). The question is, where do I get 5.x or 6.x firmware? I've tried looking, and all I can see are 7.04 and 7.08 firmware versions.
Thanks!
cabricharme
Crewman cabricharme
Crewman
Posted: โ€Ž2023-03-21 03:52 PM . Last Modified: โ€Ž2023-03-21 04:07 PM
In response to cabricharme
OK, my bad - found it (the firmware): Network Management Card 2 (NMC2) Firmware v6.6.4 Firmware for Smart UPS with AP9630/31/35 and Associ.... Will now try to update it.
... and... that worked! (Didn't even have to FTP into it - the utility did it straight up over the network. The configuration was mostly retained - but did have to redo SNMP strings.)
Is it safe to update to 7.08 now?
SzS
SzS
Cadet
Posted: โ€Ž2023-11-23 03:11 AM
Where can I download old v5.x firmware using apc firmware update utility from. The link provided above no longer works. And I have the same problem. After upgrading to 7.1.2 I can not log in.
SzS
SzS
Cadet
Posted: โ€Ž2023-11-23 03:26 AM
AG-DE
AG-DE
Cadet
Posted: โ€Ž2023-12-13 05:46 AM
1
18537
I had the same error message in browser and also UpdateUtility2 couldn't connect. So I updated 712 aos and sumx bin's as well as 109 bootmon via serial connection (57600 Baud; XMODEM). The problems stood the same. I reconnected via serial port in terminal mode (9600 Baud; user and password 'apc'). After forced password change (requirement in new OS) I did 'about' command. AOS and bootmon were ok but "Application Module --- Invalid Module Header!" Seems there was/is an update problem. Last idea was to connect via FTP. I activated via command "ftp -S enable". UpdateUtility2 still couldn't connect, but WinSCP could. I transferred apc_hw05_sumx_712.bin to the default connected (/root) folder. The file wasn't visible after upload but 'about' showed "Application Module --- Name: sumx Version: v7.1.2". Web interface then worked.
kazzic555
kazzic555
Cadet
Posted: โ€Ž2024-01-28 03:27 PM
In response to AG-DE
Thank you that fixed my issue also
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
