AP7953 Firmware Upgrade
Send InviteCancel
Posted: 2021-11-0604:29 AM
Hi Community,
I upgraded the firmware on a AP7953 PDU using "apc_hw02_aos390_rpdu374.exe" that I found on se.com. The app said the upgrade completed successfully but I was getting kicked out of the web interface after about 30 seconds so something was wrong (wasn't doing this before the upgrade).
I had another try with the same version of the firmware and it failed so I then tried with "apc_hw02_aos392_rpdu392.exe" that I downloaded from this forum. Looking at results.txt it looks like the firmware is corrupted (extract below).
I can still telnet to the device, but as with the web interface get kicked out after a few seconds. Stat reads P+ N+ A+ which I understand means things are OK (not!)
I've tried resetting to defaults and anything else I could think of but not luck. I'd appreciate any tips or advice on how to resolve this.
John
Results.txt
Using AOS file : AOS = apc_hw02_aos_392.bin Using Application file: APP = apc_hw02_rpdu_392.bin
Checking network connection ... Checking version information ... *************** Next **************
Before Upgrading the NMC the AOS is: ÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌÌ8À * Detected early version, two AOS upgrades required Attempting to log in to 192.168.1.79 ... Log in sucessful Loading OS, please wait ... Firmware download failed.
